Yes! And if you find that it fits nicely in that recess I’d like to see a photo of that.Try the seat base bottom of seat in your picture it pulls off
Thanks for posting, but your extinguisher looks a bit big for that location in our van. (I’m hoping that the Firestick fits snugly inside the recess).I'm not a fan of the firestick, but I think it would be better located here, where I have my 2kg extinguisher
When I was looking at an extingusher, I asked the professionals and this was the replyThanks for posting, but your extinguisher looks a bit big for that location in our van. (I’m hoping that the Firestick fits snugly inside the recess).
Also, why do you not like the Firestick? I was thinking about upgrading the fire blanket that I keep rolled up in between the handbrake and driver’s seat. I’m open to having my mind changed and saving some change!![]()
I guess it depends on the severity of the fire. The ‘best’ type of fire will be dealt with by putting a fire blanket over your toastie that has caught lightI carry a co2 and a dry powder. In the event of any fire my first thought would be to get out of the van. Once out the van can be flooded with the co2. Or dry powder, the least of my worries would be leaving a ‘mess’.
Thanks for all the helpful replies. I went for the firestick, as a number of people have said there is a lot of mess and clean up from powder extinguishers. If you read the blurb on the firestick it says that a 1kg dry powder extinguisher lasts 7 seconds - a firestick over 50 seconds (I’m not suggesting that means its nearly 8 times more efficient).
In the end i mounted it where i suggested and at last have found a glue that seems to stick hard plastic to plastic. Time will tell
It clears the seat when turning it round.
I popped the grill out, it is mostly blanked off and used washers behind the grill. Gives a good compromise for being able to get to it from the side door and also inside. Large stick also carried in cupboard under sink.
From memory it comes out from the rear end and thus you need to move the seat forward and access from the boot. I used a trim tool, push in at the end and it unclips, cheap trim tool pack from Amazon etc for less than £10 and super useful to avoid trim damage.I like that solution, was the grill easy to pop out?
Apologies for a tangent question, but do you still have the link for that rack? Google images has failed me.
The firestick is so light, personally I think velcro would be fine, and obvs easier wherever you decide to keep it.I like that solution, was the grill easy to pop out?
