Tow bar cost
Dave Beattie 63
Dave Beattie 63
York
T6.1 Ocean 204 4 motion
I have been quoted £1,500 from a VW dealer, seems very expensive! but my cali is only two years old and worried about warranty issues if I go for a none genuine tow bar, anyone else had one fitted recently?
I very much doubt if the VW Dealer will be fitting it. They will pass it on to a local Towbar company.
Get one supplied & fitted by PJ Jones. They will run dedicated electrics, so easily disconnected if VW try to pull the ‘this has invalidated your warranty card’
Another alternative supplier, often used by VW Dealerships
Has one fitted by VW recently but didn’t pay for it as it was part of a goodwill gesture for something they messed up. But can confirm what was said above: they don’t do it themselves. They outsource to a third-party shop. So you might as well skip the middle-man.
Only reason you might want to go VW I guess is if you had the factory-fitted towbar prep option where all the wiring for the towbar was pre-installed. A third-party shop may not be able to use that - I don’t know.
(In my case, it was a 2-year old T6.1 Ocean with the towbar prep option already fitted. Still outsourced to a third-party - don’t know which one though)
The third party shops tend to put in their own electrics rather than use VWs, I believe. But there's no reason it should invalidate warranty.
Don't forget to inform your insurer once you have towbar fitted. They tend to consider it a material modification and whether or not they can rely on that fact to decline a claim, it saves hassle just to tell them.
Thanks for all your advice, I have a couple of quotes now around £850 so will be going down the none VW rip off route and saving myself £650!
