Replaced T6 ABS Rear Right Sensor - 'incorrect component'
  • Thread starter California Dreamin
  • Start date
California Dreamin
California Dreamin
Rickmansworth, Hertfordshire
T6 Beach 150
I had a whole bunch of abs/ tyre warning etc light appear and carista reported rear right abs sensor faulty. I replaced it with a vw oem WHT003856C. It is the same as the original part number except it has a c on the end. The old one had no revision letter. I thought this was just a revision number so would be fine. Now I am getting carista code C101D4A Right Rear ABS Wheel Speed Sensor - Incorrect Component Installed
Would replacing the nearside with the rev c one help
(i have it but haven't put it on yet. I only have street parking so its quite difficult so stopped after the side with the code hoping it would be sorted.
Any help very much appreciated.
Wht003856 is valid from 01/06/21 onwards, the part number with a C suffix isnt listed as compatible
Weirdly enough, I've just had the exact same thing happen on my 2016 Beach. Replaced the faulty sensor with and admittedly very cheap version (£10 ebay!), and all the codes have gone except the "Incorrect component" one :-(
And didn't know whether it was down to some VW income component protection system, or just a cheap nasty sensor.
Anyone know which brands trigger this "Incorrect component" warning, and which don't?
Thanks!
I’ve replaced a couple of those albeit on a T5.1 and always used somewhere like Eurocarparts or Autodoc which seem pretty good at identifying the right parts based on your reg and whilst more expensive than eBay still a lot cheaper than VW even for Bosch or similar parts
Used APEC part no ABS 1009 on ours no errors last year
Thanks!
I fitted replacement Sensors all round on my 17MY 4Motion
Bosch parts 0 986 594 504 and 0 986 594 505
I had a similar issue when replacing ABS sensors on my wife's Golf.
The sensors differ when the vehicles have/ don't have adaptive cruise control. You need the (usually dearer) correct ones even though they can look similar at first.
I've used both Ridex and Febi Bilstein bought through Autodoc, all good.
Thank you for all the replies. I reordered the part an used Autodoc and indeed they supplied the right part and all the codes reset and dash now normal. Even managed to change it without removing the wheel or jacking up, just lying under the van. Much easier once you've been in there once and know where everything is. So satisfying to see all the waring lights go out.
Thank you for all the replies. I reordered the part a used Autodoc and indeed they supplied the right part and all the codes reset and dash now normal. Even managed to change it without removing the wheel or jacking up, just lying under the van. Much easier once you've been in there once and know where everything is. So satisfying to see all the waring lights go out.
For ultimate satisfaction you could phone a VW garage and get them to quote for replacing one
Just for the fun of it I just called my local dealer to ask price on part only for rear right abs sensor........£107...........its beyond a joke. Autodoc to the rescue
mountainman
mountainman
mountainman
Ozzy Pete
Ozzy Pete
SqueakyWheel
pjm-84
pjm-84
