Bike rack/ tow bar
MJM Grand
London
T6.1 Ocean 150
Hello all,
We’ve got a MY2024 t6.1 Ocean and I’m looking into options for carrying bikes. I have sounded out towbar providers and all say that vw have made a change to the CPU which means they can’t code in a towbar properly. So if we get a towbar, it would mean issues with sensors when bike rack is on. Has anyone else encountered this?
Separately, I’m looking at racks for the boot door. Struts we have are 1240N would we need to upgrade if we get a 4 bike rack on the door?
Thanks in advance
If your preference is the tow bar mounted carried route, then I would check with satnavsystems.com Hamid Ataie (if you have not done so) as if anyone can he will solve the electrics isse you describe.
https://www.satnavsystems.com/
We have electric bikes and in our 70's so other higher level alternatives would not work. I know nothing about the boot door route, only that the VW rack is permanent and looks a pain. But a search on the forum ( with VIP membership ideally so you can be more date selective) may give you answers.
Hello all,
Thanks in advance
We had a (non VW) towbar fitted to our 74 plate by the dealer for our towbar mounted bike carrier. . I'm pretty sure they wouldn't have done it if there was coding issues that would cause the sensors to have issues.
Have the fitters you've spoken to mentioned exactly what issues you'd face?
I must be honest, we haven't used our yet - but with an upcoming trip where it will be needed we were saying about a trial run.
I'll get that done and let you know if anything untoward appears but all I'm expecting is for the rear sensors to become inactive and the side assist not to work.
With regard to getting a boot mounted one, the recommendation is to upgrade the standard struts, but if you have 1240N then it sounds like you may have the stronger ones anyway.
Hi @AdamsFamily, it turns out advisor got it wrong and we should be fine to get towbar coded in! Was useful to reference your experience - thank you. Am now booked in to get sorted.
We have a factory fitted towbar and when there’s a light board attached the auto cruise control seems to be disabled (which might well make sense if there was a caravan or trailer being towed). I’m not sure what else would apply.
Auto cruise control continues to work fine on my MY23 Ocean with my Thule tow bar mounted bike rack with auxiliary lighting connected. But lane assist and the rear sensors are both disconnected.
Interesting, and annoying if that's the case. Our Volvo just disabled the side assist and rear sensors - could still use adaptive cruise which is a must through France.
H
5K
AlanC
G
sebking
sebking
MacCali
