Levelling ramps
I use a pair of Flat Jacks, they work really well on those grass pitches and you want the scenic spot away from anyone else.
They’ll lift a wheel over 7 inches, which is more than many plastic wedges and store flat.
I also recommend some form of mat underneath just in case of a sharp stone.
https://www.flat-jack.nl/en/frequently-asked-questions/
I think these are a good idea, I looked at something similar. In the end I went for Uniko 6 in 1, though they probably take up too much space in an Ocean.
Aah, the big question. Is tech your friend?
I use two means to get level (ish). I check to see if the sliding door stays where I leave it , for front to back level. I open the KnifeSharp and fork draw - level side to side if it stays where I leave it. Takes couple of seconds and accurate for sleeping and cooking.
I got these as they come with the wheel chocks that slot onto the ramps. Levelling ramps are rarely used but when you need them, you have them!! We keep ours as others have said in the bit by the pull out drawer. Fit perfectly there and easy access.
https://amzn.eu/d/cbBQcKD
Jeremy Auton
Ch1pbutty
Ch1pbutty
Ch1pbutty
Accessories For Sale Large Levelling Ramps
SoulfulSteve
kellyscali
kellyscali
kellyscali
