How to Fix Kitchen Tap and Water Pump Problem and solution.
Cali-61-180-SE
Cali-61-180-SE
HI had this problem long weekend. I top-up water and start kitchen tab but water doesn't come even no pump sound. So i start investigation step by step.
1: First Check Fuse is fine or not. use multimeter continuity test. i found fuse was blown.
2nd step: after replacing 5mp new fuse, check again and start tab. In my case no success.
3rd Step: Opening water tankand check 12v current is coming or not. make sure tab is ON. to open water tank lid i made one tool. before open make sure disconnect both water pump and level sensor connection.
(My case 12v current is available after fuse change.)
4th Step: If 12v current is available it means something wrong in pump so remove water pump. i have close looked remove water pump and found its overheated and burning smell also coming. when i close looked also found water lime-scale. white power in side the pump. i think water lime-scale created the problem.
Big applause for this !
This can help to solve many asked questions here.
Probally one of the most common faults on the Cali , so very nice detailed report:thumb
Will that then be in the download section?
Yes, we can have a copy on forum and copy in downloads for people to print out.
I want to add one more thing. In all this process I did one thing wrong. When you cut connector from old water pump make sure cut little extra wire so you can attach new one with out any problem. I cut very sort but after little fights I have managed to connect new pump.
Great illustration of the process - thank you.
Note: How did you connect the wires from the new replacement pump to the existing switch?
Many thanks
I cut little extra wire from old pump and attached with new one and use electric tap. But I think above cavin idea is better then my one.
JK
Excellent post. Thanks!
Question on the tool you used for unscrewing the pump:
Could you give me measurements of this tool?
That would be very helpful. Unless of course there are different pump sizes...
