BioMagic Ultimate Fresh Water Tank Cleaner
£34.99 Inc VAT
Only 2 left in stock
This product is designed to remove the worst contamination from fresh water tanks including diesel! it is also ideal you have purchased a new campervan and you are unsure how the fresh water tank has been used in the past as this will make it like new again!
BioMagic Fresh Water Tank Cleaner, Will Treat up to 150-litres twice!!! This amazing product will even remove the taste and smell of diesel from your fresh water tank if it has been contaminated with fuel. As long as you follow the instructions on the bottle your tank will be as good as new after the treatment. The only other alternative is to strip out the fresh water tank and all pipes that have been contaminated and replace them at a very high cost
  • Biologically Friendly
  • 100% Safe to humans, animals and plants
  • Removes the smell and taste of diesel from your fresh water tank
  • Easy and simple to use
  • Concentrated
BIOM1
Weight 1.500 kg
Dimensions 21 × 21 × 21 cm
Be the first to review “BioMagic Ultimate Fresh Water Tank Cleaner”
£34.99 Inc VAT
