Brandrup Isolite Outdoor Plus EXTREME for the Cabin Windows of the VW Multivan/California (T7) – 3 Pieces
What is included?
- 1 x Isolite Outdoor Windscreen Cover
- 2 x Isolite EXTREME inserts for the cab windows (drivers’ & passengers’ windows)
EXTREME – The “sandwich material” consists of the proven ISOLITE material, a flame-retardant special thermal fleece, and the elegant, flame-retardant original VW T7 California blackout fabric: insulation, functionality, and a pleasant indoor climate are all optimal.
Each ISOLITE® Extreme mat for the VW T7 cab side windows consists of two sections connected by a flexible joint. This allows the upper section of each mat to be folded down and secured when using the VW ventilation insert or the FLYOUT for the driver/passenger windows. In cold weather, the upper section can be folded up and secured. When the door is closed, the window is “double-glazed” and provides excellent insulation
Installation is very easy and can be done by one person:
ISOLITE Outdoor is a perfect fit and is simply placed on the windshield and attached to the inside of the A-pillar with hook-and-loop fasteners.
When the door is closed, the ISOLITE Outdoor bracket clamps into place, securing it.
The ISOLITE ® Extreme mats for side windows are attached to the window frame with small hook-and-loop fasteners.
When the door is closed, the ISOLITE Extreme is pressed against the door seal, creating a complete seal on three sides.
A hook-and-loop fastener strip is also included at the bottom, which can be applied to the trim if a complete all-around seal is desired. This creates a generous double-walled insulation:
The air trapped between the window pane and the ISOLITE cannot circulate and escape upwards (summer) or downwards (winter).
The ISOLITE ® Case can be used for transport, which can also be used with the ISOLITE ® fastening strap set on the VW California Ocean / Coast
Made in Germany
Design: “Silver/Sandwick”
100 701 680
Frequently bought together
- Brandrup Anti-Slip Protective Mats for Cupboard Compartments of VW Multivan California (T7) – Set of 9Add to basket
- Brandrup Flexbag Stern for VW Multivan California Ocean/Coast (T7) – Leather RavenPre-Order
- Brandrup Isolite Storage Case for VW Grand California/VW Multivan California (T7) – Outdoor/Outdoor Plus/Outdoor Plus Extreme VersionPre-Order
- Brandrup Isolite Storage Case for VW Multivan California (T7) – Extreme/Inside VersionsPre-Order
You may also like…
Comfortz VW Multivan (T7) California Ocean Mattress Topper
Price range: £99.99 through £129.99 Inc VAT -
Comfortz VW California Multivan (T7) ‘Cali-Wrap’ – Thermal Roof Wrap
Price range: £279.99 through £379.99 Inc VAT
£204.99 Inc VAT
