CampervanBits Tie Down Kit for VW California & Thule Awnings – INC Storage Bag
Designed specifically to fit the VW California & Thule Wind-Out (Roll-Out) Awnings.
Secure your awning down during harsher weather conditions, or add extra rigidity and security whilst you’re pitched.
How to install
- Slide the metalwork into the gap at the top of your support legs (see images)
- Thread the second part of the strap into the buckle
- Slide the hook of the shock-absorbing springs onto the triangle at the end of the strap
- The other end of the spring slides nicely around the hook of the anchor peg
- Pull to the desired length and secure the peg into the ground
If the strap requires more tension, this can be achieved by pulling on the strap threaded through the buckle
What is included?
- 2 x storm anchor pegs (38cm in length)
- 2 x 3m nylon webbing straps (side that has the triangle for securing)
- 2 x 66cm nylon webbing straps (side that goes into the support leg)
- 2 x 10cm shock absorbing springs
- Water Resistant Storage Bag (colour of bag may vary slightly)
Frequently bought together
CampervanBits Tie Down Kit for VW California Mercedes Marco Polo & Thule Awnings – INC Storage Bag
£19.99 Inc VAT
