CampervanBits VW Multivan California (T7) Awning Rail Washing Line
£54.99 Inc VAT
Only 1 left in stock
SKU: 5060641654425 Category: Tag:
Do you struggle to find somewhere to dry your towels after a shower or a beach day, or perhaps hang a couple of t-shirts or shorts that have been washed when on longer adventures?
Effortlessly gliding into the VW California awning rail, our awning rail washing line is the perfect solution.
Within minutes, the washing line can be installed and can start drying your belongings!
The steel brackets are powder-coated in black to withstand the elements, paired with the black washing line cord: this compliments any van.
With one continuous length of line threaded between each bracket, the washing line can be pulled tight whilst in the awning rail and has a good space for hanging multiple items.
How is it installed?
Already assembled, you will see the washing line is made from two black powder-coated brackets, where the line is threaded through and knotted tightly.
Attached to these pieces are two thumbscrews, the flat metal piece simply slides into your awning rail, the line can then be positioned to suit your needs: tighten the handwheels to ensure the product does not move.
To remove: simply ensure the line is empty, slowly unscrew the handwheels, and slide the line out gently!
Worried that the brackets might scratch your rail?
There’s no need to worry, we have attached soft velcro to the part that slides against your rail to ensure no marks are left!
Check out our growing range for the VW Multivan California (T7) HERE
Please Note: our images mainly show the washing line installed on a VW California T6, this washing line fits in the same way although the brackets are curved to fit your van! Rest assured, this is for the T7 🙂
CampervanBits
Be the first to review “CampervanBits VW Multivan California (T7) Awning Rail Washing Line”
£54.99 Inc VAT
