Colapz Flexi-Waste Pipe Adaptor
£4.95 Inc VAT
Only 2 left in stock
SKU: 5060070215068 Categories: , ,
The Colapz Flexi Waste Pipe adaptor will allow you to fit your waste pipe to diameters from 19mm up to 50mm. The clever rubberised adaptor allows you to easily fit or cut the connecting point to your waste water pipe to the required diameter and then connect to the Colapz Flexi Waste Pipes which are available as a kit or individually. The adaptor is easy to clean and store and is the perfect extra to accompany your flexi waste pipe kit.
  • To be used with the Colapz flexi waste pipes
  • Fits 19mm to 50mm diameter waste pipes – Ideal for motorhomes
  • Very easy to cut to the required diameter
  • Easy to clean and store
Specifications
  • Approximate length: 18cm ( can be cut to size)
  • Fits 19mm to 50mm waste pipe
80036
Pennine Leisure Supplies
Caravan, Motorhome, Campervan Conversion and Camping Accessories, Spares & Leisure Appliances.
Be the first to review “Colapz Flexi-Waste Pipe Adaptor”
£4.95 Inc VAT
