No more long smelly awkward waste pipes! Very easy to link and adjust to required length Easy to angle, so you can direct the water exactly where you want it to go Lightweight and robust, enhanced with quality UV stabilisers Easy to clean and store Kit includes 4 x 1 metre length flexi-pipes (8pc pipe kit available here) DOUBLES in length from 50cm to 100cm (1 metre) Includes silicone brush cleaner fitted with a 1 metre metal chain Includes handy storage bag Additional 1 metre flexi-pipe lengths available to purchase here Metal pegs which help to support the waste pipe at the correct position available to purchase here. Fits standard caravan 29.5mm waste outlet, however, an adaptor to fit 19mm to 50mm diameter waste pipes are available to purchase.
Feature
- Set of 4 in a box
- Extends From 50cm to 100cm
- Can be linked together
- Lightweight and robust
- Easy to clean
- Includes Carrybag
- Easy to store
- Includes cleaning brush
80030
