Colapz Waste Pipe Double Adaptor
£12.99 Inc VAT
Only 2 left in stock
SKU: 5060070214825 Categories: , ,
The Colapz Waste Pipe Double Adaptor has been designed to fit standard 28.5mm double waste pipe outlets fitted on most modern caravans from the year 2000 onwards. The adaptor has been made out of a rubberised material so that it is easy to cut to size with scissors or a sharp knife, and when fitted to the caravan it provides a snug watertight fit. The kit includes a three-piece double adaptor with a 15cm downpipe and a handy storage bag to keep it all together when not using it. The adaptor has a 6cm adjustment, so will fit most double waste outlets with 7cm to 13cm between the centres. The internal curves to the double adaptor allow free-flowing water and prevent any potential backwash to the shower or basins. Full assembly instructions are listed on the outer packaging for ease of fitting. Please check your outlet size before ordering – compatible with 28.5mm waste outlets.
  • Fits most 28.5mm standard double waste pipe outlets fitted on caravans year 2000 onwards
  • Kit includes double adaptor, 15cm downpipe and storage bag
  • Easy to cut rubberised material to the required size
  • The rubberised material makes it easy to fit into your caravan waste outlets and provides a watertight seal
  • Internal curves allow free-flowing water
  • Connects easily to Colapz flexi-waste pipes to provide a watertight seal
  • Easy to clean and store in the drawstring bag provided
Specifications
  • 6cm adjustment, so will fit most double waste outlets with a 7cm to 13cm between centres
  • Compatible with 28.5mm waste outlets
  • Four section part kit included
80032
Pennine Leisure Supplies
Caravan, Motorhome, Campervan Conversion and Camping Accessories, Spares & Leisure Appliances.
Be the first to review “Colapz Waste Pipe Double Adaptor”
£12.99 Inc VAT
