Sale!
Comfortz Sun Shadz Side Panels for Fiamma F45s 3m Awnings Sun Blocker
Comfortz Sun Shadz Side Panel Set for Fiamma F43 Van Awning 2.7m
Original price was: £159.99.Current price is: £129.99. Inc VAT
Zipped around the support bars of your wind-out awning, the Comfortz Sundhadz Side Panel Set can either be used on their own, as a pair or to extend the versatility of the front panel even further.
Flexible privacy and protection and is set up in just a few minutes with reliable stability assured through the use of guylines and ground pegging points. Both panels can be pitched either down to the floor with bungee attachments or out an angle with the included guy lines and pegs.
All the panels can be used with tarp poles (not included) to extend the footprint of your roll-out awning to create a larger shaded area.
Manufactured here in the uk with 12 months warranty and onsite repairs available.
This is designed for a standard VW T6 / T6.1 height vehicle so will also work with vehicles of a similar height.
Please be aware some of the earlier models of the Fiamma F43 Van wound out (projected) further from the van than the current models – please wind your awning out and double-check the projection length. Option 1 is 185cm and Option 2 is 225cm.
  • Provides shade, shelter and privacy
  • Attaches to wind out awning or roll out awning
  • Angle from awning or vehicle can be adjusted
  • Can be used with king poles (not included)
  • Attaches using heavy duty zips
  • Fast and easy to attach and detach
Specifications
  • 300 denier UV protected polyester (a more durable fabric than others on the market)
  • Pack size:TBC
  • Weight:TBC
  • Colour Grey.
Projection from the van
185cm, 225cm
Comfortz Leisure
Comfortz Leisure is a small family run business specialising in custom-made accessories for your VW California, campervan or caravan.
Be the first to review “Comfortz Sun Shadz Side Panel Set for Fiamma F43 Van Awning 2.7m”
You may also like…
  • Comfortz Sun Shadz Front Panel Tarp for 2.6m Awnings – California, Marco Polo, Fiamma, Thule, Dometic, Omnistor
  • Vango Adjustable Steel King Poles ( 180-220cm)
Subtotal: £265.98
View basketCheckout
