The Connect Deep Pan and Griddle Granite Edition features detachable cool-touch handles and a detachable hinge system that transforms one pan into two – a deep sided saucepan and a separate griddle pan.
The griddle pan acts as the lid on the deeper pan, and can be detached to become a separate pan, allowing you to cook two lots of food at once.
Our all-new granite-style coating makes our pans tougher, more durable, and offers improved non-stick properties taking compact cookware to a whole new level.
  • Deep Pan and Griddle – Granite-style coating with improved non-stick properties
  • 1x griddle pan
  • 1x deep sided saucepan
  • 1x set of removable magnetic, thermoset plastic cool-touch handles with protective pouch
  • Detachable hinge system
  • Lightweight aluminium construction
  • Sleek Gunmetal Grey finish
  • Ridged exterior for even heat transfer
  • Protected registered design
  • Can be used on all traditional stoves and direct heat sources (not suitable for use on induction hobs)
Approximate dimensions:
180mm (295mm with handles) x 155mm x 100mm
Weight
670g (full pan, including handles)
395g (deep sided pan)
275g (griddle pan)
Capacity:
1.2 litres
RM778
Type
With Standard Case, With Free Gorilla Case – Worth £19.99
Ridgemonkey
RidgeMonkey, brings to market a range of products that make a difference to anglers, campers, and outdoor living.
Be the first to review “Ridgemonkey Connect Deep Pan and Griddle Granite Edition”
You may also like…
  • RidgeMonkey DLX Standard Plate Set – Twin Pack
    Original price was: £12.99.Current price is: £9.99. Inc VAT
£26.99 Inc VAT
Subtotal: £870.91
View basketCheckout
