Dometic CFX3 45 Portable Compressor Fridge or Freezer New
£784.99 Inc VAT
Out of stock
Email Me When Back in Stock
Dometic CFX3 45 Portable Compressor Fridge or Freezer 12v 24v 240v Here we have the extremely impressive range-topping portable fridge from Dometic.
On-road, off-road, on the water or anywhere you want to enjoy fresh food, cold drinks or even ice cream. Explore how the Dometic CFX3 45 is as versatile as you and your next adventure.
- Generous storage capacity of 40 l
- Heavy-duty yet lightweight ExoFrame construction with fender frame protected edges and aluminium alloy handles
- Powerful VMSO3 compressor cooling technology efficiently refrigerates and deep-freezes to –22 °C
- Easy-to-read High-Resolution Colour Display and soft-touch buttons enabling seamless control and monitoring of cool box performance
- CFX3 App allows temperature control via WiFi or Bluetooth and provides performance history
- 3-stage dynamic battery protection system prevents dead car battery or allows deep draw on dual batteries
- Active Gasket Technology provides a superior seal to retain cool air and minimise power consumption
- Mobile App keeps detailed records of the temperature and power consumption history (Android and IOS)
Specifications
- Dimensions – depth 694 mm, height 476 mm, width 398 mm
- Net weight 18.7 kg
- Gross volume (EN62552) 46.00 l
- Storage volume – total (EN 62552) 40.00 l
- Input voltage (AC) 100-240 V
- Input voltage (DC) 12/24 V
- Rated input current (AC) 0.96A at 100V, 0.40A at 240V A
- Rated input current (DC) 8.2 A
- Rated input power (AC) 52 W
- Input frequency 50/60 Hz
- Colour Slate / Mist
- USB Port 5V, 2A
- Connectivity Type Bluetooth, WiFi
- Basket Yes
- Threaded inserts in base for mounting M6
- Drain plug Yes
- Anti-condensation coil Yes
- Interior light Yes, LED
- Certificates ECE R10, CB, CE, GS
- Cable length supply cable 2.00 m
Performance
- Refrigerant, type R134a
- GWP 1430
- Refrigerant amount 42 g
- CO2 equivalent 0.06 t
- Average energy consumption at AC (EN62552) 0.22 kWh/24h
- Energy Consumption 12 V DC (Ambient@90 ºF, Internal@39 ºF) 1.03 Ah/h
- Energy class EU (1060/2010/EC) A++
- Climate class (EN62552) N/T
- Insulation Thickness 55.00 mm
- Insulation Type PU (Polyurethane)
9600025327
