EcoFlow 60W USB-C Portable & Foldable Solar Panel + VW California / Campervan Fitting Kit
£124.99 Inc VAT
SKU: 4895251629720 Categories: ,
EcoFlow 60W Portable & Foldable Solar Panel Kit VW California / Campervan.
The Kit includes The Ecoflow 60W solar panel, 6ft USB-C to USC-C Cable, Dc 5521 to XT60 Cable and Fitting Kit.
The fitting kit will work with 6mm, 4mm and California awning rails, Thue, Dometic and Fiamma Roll out Awnings or can be used in conjunction with a bike rack or roof bars ect.
Ideal for direct charging, Phones, Laptops, Tablets, Rechargeable air pumps, power banks, power stations, hair straighteners ect
Small and light when packed away, easily stowed and ideal for the campervan, caravan, camping and of grid. Pack Size is 31cm x 31cm x 4.5cm (at its thickest point) – 2kg
Specifications – 60w Solar Panel
60W Portable Solar Panel (Type-C) includes a Type-C output port to direct charge devices like phones, laptops, and air pumps. Experience the utmost convenience with our 60W Portable Solar Panel (Type-C).
  • With the introduction of TOPCon solar technology, a first in the mini portable solar panel industry, we’ve set a new standard for conversion efficiency, achieving 25%. This enables faster charging in a more compact form. Fully charge RIVER 3 in 4.7 hours during peak sunlight hours, and power your electronics and essential camping appliances for a longer adventure.
  • With its folding four-panel structure, the portable solar panel significantly reduces in size when folded, allowing it to easily fit into compact spaces such as backpacks, SUVs, or minivans.
  • Featuring robust PCB fibreglass and a durable ETFE coating, our panels are designed to withstand challenging weather conditions. Whether it’s a sudden impact, being pulled by the wind, or even exposure to salty ocean spray and water droplets, they remain undamaged and strong, serving as your reliable outdoor companion.
  • In addition to being laid flat on the ground or tilted using a stand, the 60W portable solar panel can be hung using the four pre-cut eyelets and hooks included. Whether hung on your car or backpack, save time by charging while you’re heading to your next destination.
  • With its compact design and lightweight, a 60W portable solar panel is the ideal companion for RIVER Series power stations, providing a simple and convenient charging experience.
  • Size Packed down
What comes with the fitting kit.
1 x 60W Ecoflow Folding Solar Panel
1 x Anker – 6ft usb-c to usb-c charging cable
1 x Dc 5521 to Xt60 Cable
4 x Carabina
2 x Guylines
2 x Bungee fittings
2 x Dual beading awning rail attachments (4mm, 6mm and VW California Compatible)
2 x Steel pegs
1x Storage bag for the the fitting kit
The guylines and pegs are designed to angle the solar panel away from your campervan – 1, to catch the sun better and 2, to avoid damage to the painwork. Please do not over stress the solar panel by putting too much tension on the guylines.
Please note, the power bank and phone within the pictures do not come supplied with this item.
Model
Delta 3, Delta 3 Plus
Ecoflow
Be the first to review “EcoFlow 60W USB-C Portable & Foldable Solar Panel + VW California / Campervan Fitting Kit”
You may also like…
  • EcoFlow DELTA 3 and Plus Series Portable Power Station
    Price range: £649.00 through £699.00 Inc VAT
    View product
  • EcoFlow DELTA 3 1500 Portable Power Station (1536Wh)
    Original price was: £999.00.Current price is: £949.00. Inc VAT
£124.99 Inc VAT
