Fiamma Carry Bike Tailgate Bike Rack for Ford Tansit Custom and Nugget Inc Plus
Fiamma Carry Bike Tailgate Bike Rack for Ford Transit Custom and Nugget Inc Plus
£459.99 Inc VAT
Special model designed to fit the rear tailgate of the Ford Transit Custom, Tourneo and Nugget (incl Plus). Easy installation without drilling the vehicle with the brackets which are delivered as standard.
The Fiamma Carry Bike is a stylish design that harmoniously follows the line of the ford without covering lights and number plate. Simplicity and speed of installation / de-mounting and excellent rigidity on the rear of the vehicle.
The Fiamma Carry Bike carries 2 bikes as standard and can be upgraded to carry 3 bikes with optional extra kit.
The stylish design harmoniously follows the line of the vehicle without covering lights and numberplate. The rear door / tailgate can be raised with the bike carrier fitted.
Simplicity and speed of installation / de-mounting and excellent rigidity on the rear of the vehicle. The Carry Bike is installed without drilling the vehicle so it can easily be removed when not in use.
The upper brackets are fastened to the reinforced points of the rear of the vehicle, brackets are complete with plastic supports in the centre of them, free from any hooks the lower part of the vehicle does not lean against the bumper.
Equipped with double lower reinforcing bar to ensure maximum stability.
Please Note: These can only be shipped within the United Kingdom
A0012466
Vehicle Compatibility
Tailgate models only with no roof spoilers
  • Ford Custom
  • Ford Transit Custom
  • Ford Tourneo Custom (2012+ – H1) also for models with lift roof
  • Ford Transit Custom Nugget Plus (2012+)
  • Ford Transit Custom Nugget (2015+)
  • Ford Cap Land (2015+)
  • Ford Cap Fan (2015+ to 2018)
  • Ford Cap Coast (2018+)
  • Ford Cap Life (2019+ – H1)
Specifications
  • Capacity: Two bikes carried as standard – Maximum 3 bikes!
  • Weight: 8.2kg
  • Dimensions:W:156cm x D:46cm x H:80cm
  • Maximum Weight Capacity: 50kg
  • Distance Between Rails: 15cm
Fitting Instructions
Fiamma
Fiamma is a leading company in manufacturing technical accessories for motorhomes, caravans, van conversions, and campervans.
Be the first to review “Fiamma Carry Bike Tailgate Bike Rack for Ford Transit Custom and Nugget Inc Plus”
You may also like…
  • Fiamma Premium Awning Tie Down S Kit – Black
  • Fiamma Level Ups (Inc Carry Bag) GREY
  • Fiamma Grip System - Pair
£459.99 Inc VAT
