Have a Fiamma F45i which has a damaged hand winch cover?
This replacement left-hand winch cover will make your awning look as if it’s just been put on your van, simply pop the damaged one off and pop the new one back on. In polar white it will give your van’s awning the complimentary finishing touch you’re looking for.
This cover fits any Fiamma F45i awnings from between 250 and 4o0 in length, on the winch side of the awning.
This cover should also fit any Fiamma ZIP awning with lengths of 200, 300 and 350.
Frequently bought together
| Part | 1 CONNECT. SUPP. ARM, 10 LH+RH SIDE CAP ASSY ANTHRACITE, 10 LH+RH SIDE CAP ASSY GREY, 11 LH SPRING ARM COMPLETE, 12 RH SPRINGARM COMPLETE, 13 LH+RH LEAD RAIL END PLATE ASSY ANTHRACITE, 13 LH+RH LEAD RAIL END PLATE ASSY GREY, 14 SUPPORT ARM V2 2.60M, 15 CENTRAL CLAMP SUPPORT ARM V2, 16 LH+RH CONN.LEAD RAIL, 17 ADAPTER SET, 18 LH+RH ROLLER BEARINGS, 19 POSITIONER SPRING ARM 5102 2PC, 2 ROLLER TUBE ASSY 2.6M, 3 COMPLETE FABRIC 2.60M, 4 HAND CRANK, 5 MAIN HOUSING ANTHRACITE, 5 MAIN HOUSING GREY, 6 OUTSIDE LEAD RAIL ANTHRACITE, 6 OUTSIDE LEAD RAIL GREY, 7 INSIDE LEAD RAIL, 8 LH END PLATE + GEAR ASSY, 9 RH ENDPLATE |
| Part | 1 CONNECT. SUPP. ARM, 2 ROLLER TUBE ASSY 2.6M, 3 COMPLETE FABRIC 2.60M, 4 HAND CRANK, 5 MAIN HOUSING ANTHRACITE, 5 MAIN HOUSING GREY, 6 OUTSIDE LEAD RAIL ANTHRACITE, 6 OUTSIDE LEAD RAIL GREY, 7 INSIDE LEAD RAIL, 8 LH END PLATE + GEAR ASSY, 9 RH ENDPLATE, 10 LH+RH SIDE CAP ASSY ANTHRACITE, 10 LH+RH SIDE CAP ASSY GREY, 11 LH SPRING ARM COMPLETE, 12 RH SPRINGARM COMPLETE, 13 LH+RH LEAD RAIL END PLATE ASSY ANTHRACITE, 13 LH+RH LEAD RAIL END PLATE ASSY GREY, 14 SUPPORT ARM V2 2.60M, 15 CENTRAL CLAMP SUPPORT ARM V2, 16 LH+RH CONN.LEAD RAIL, 17 ADAPTER SET, 18 LH+RH ROLLER BEARINGS, 19 POSITIONER SPRING ARM 5102 2PC |
