Fiamma Right Hand Winch Cover F45i Polar White
£11.49 Inc VAT
Only 2 left in stock
Have a Fiamma F45i which has a damaged hand winch cover?
This replacement right-hand winch cover will make your awning look as if it’s just been put on your van, simply pop the damaged one off and pop the new one back on. In polar white it will give your van’s awning the complimentary finishing touch you’re looking for.
This cover fits any Fiamma F45i awnings from between 250 and 4o0 in length, on the winch side of the awning.
This cover should also fit any Fiamma ZIP awning with lengths of 200, 300 and 350.
Part
1 CONNECT. SUPP. ARM, 10 LH+RH SIDE CAP ASSY ANTHRACITE, 10 LH+RH SIDE CAP ASSY GREY, 11 LH SPRING ARM COMPLETE, 12 RH SPRINGARM COMPLETE, 13 LH+RH LEAD RAIL END PLATE ASSY ANTHRACITE, 13 LH+RH LEAD RAIL END PLATE ASSY GREY, 14 SUPPORT ARM V2 2.60M, 15 CENTRAL CLAMP SUPPORT ARM V2, 16 LH+RH CONN.LEAD RAIL, 17 ADAPTER SET, 18 LH+RH ROLLER BEARINGS, 19 POSITIONER SPRING ARM 5102 2PC, 2 ROLLER TUBE ASSY 2.6M, 3 COMPLETE FABRIC 2.60M, 4 HAND CRANK, 5 MAIN HOUSING ANTHRACITE, 5 MAIN HOUSING GREY, 6 OUTSIDE LEAD RAIL ANTHRACITE, 6 OUTSIDE LEAD RAIL GREY, 7 INSIDE LEAD RAIL, 8 LH END PLATE + GEAR ASSY, 9 RH ENDPLATE
Part
1 CONNECT. SUPP. ARM, 2 ROLLER TUBE ASSY 2.6M, 3 COMPLETE FABRIC 2.60M, 4 HAND CRANK, 5 MAIN HOUSING ANTHRACITE, 5 MAIN HOUSING GREY, 6 OUTSIDE LEAD RAIL ANTHRACITE, 6 OUTSIDE LEAD RAIL GREY, 7 INSIDE LEAD RAIL, 8 LH END PLATE + GEAR ASSY, 9 RH ENDPLATE, 10 LH+RH SIDE CAP ASSY ANTHRACITE, 10 LH+RH SIDE CAP ASSY GREY, 11 LH SPRING ARM COMPLETE, 12 RH SPRINGARM COMPLETE, 13 LH+RH LEAD RAIL END PLATE ASSY ANTHRACITE, 13 LH+RH LEAD RAIL END PLATE ASSY GREY, 14 SUPPORT ARM V2 2.60M, 15 CENTRAL CLAMP SUPPORT ARM V2, 16 LH+RH CONN.LEAD RAIL, 17 ADAPTER SET, 18 LH+RH ROLLER BEARINGS, 19 POSITIONER SPRING ARM 5102 2PC
Fiamma
Fiamma is a leading company in manufacturing technical accessories for motorhomes, caravans, van conversions, and campervans.
Be the first to review “Fiamma Right Hand Winch Cover F45i Polar White”
You may also like…
  • Maypole Epsom Woven Awning Carpet 250cm x 250cm
£11.49 Inc VAT
