Sale!
FullStop KoJack Single Axle Hydraulic Jack
Original price was: £89.95.£85.99Current price is: £85.99. Inc VAT
Out of stock
Email Me When Back in Stock
Custom designed brackets allow you to easily and effortlessly jack & level your caravan without the need for drilling your caravan chassis, which can void your warranty. Kojack fits 99% of caravans.
“Wherever you park your motorhome or caravan you can always have the perfect pitch”
Designed in the Purple Line’s UK innovation centre, the 3-Tier hydraulic bottle jack connects to the dedicated safe anchor points, which are attached to your chassis. The brackets bolt into pre-existing holes that are standard on most AL-KO & BPW chassis.
Kojack has full TUV CE accreditation and a safe working load (SWL) of 2000kg.
The kojack set includes a 3-tier hydraulic bottle jack, 2 x chassis brackets with integral spirit levels and all necessary fittings an fixings.
Specifications
- Safe working load (kg)| 2000
- Colour| High visibility orange
- Compressed dimensions (mm)| 170H X 140W X 130D
- Extended dimensions (mm)| 390H X 140W X 130D
- Weight (kg)| Jack – 4.7 Package – 6.1
- Bracket type | L-Bracket
- Number of brackets included | 2
- Bracket spirit levels included
- L-Bracket dimensions (mm)| 155H X 950W X 60D
- L-Bracket weight (kg)| 0.7
- Hole spacing from centre (mm)| 55
KJ4000S
Frequently bought together
Reviews (2)
2 reviews for FullStop KoJack Single Axle Hydraulic Jack
![7844966-po314-2-3-560[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2025/10/7844966-po314-2-3-5601.jpg)
John Spearman (verified owner) –
excellent piece of kit. simple to fit using a T square, spanner and torque wrench, my only concern is the 3 piece jack handle which is a potentially weak point, with a heavy caravan, fully loaded the handle could bend at the points where it is joined.
As mentioned on other reviews of this product elsewhere the paintwork is very brittle and flakes easily, so a touch up with a bit of paint will prevent early rusting
Steven Jones (verified owner) –
Spot on piece of kit. Hope I never need to actually use it but now safe in the knowledge ‘if’ I ever do need to jack up and change a wheel I’ve taken one element of stress out of the situation. Great people to deal with as well, fast delivery and well informed
