FullStop Thatcham Nemesis Ultra Multi-Purpose Wheel Lock (FNU200)
The Nemesis Ultra is a world-leading multipurpose wheel lock. It is suitable for both Alloy & Steel wheels and can be fitted and secured using only one hand in under 10 seconds.
The Nemesis Ultra makes securing your caravan or trailer quick and easy, allowing you to use the Nemesis Ultra at times when other wheel clamps and locks would not be suitable such as service stations and car parks. The Nemesis Ultra incorporates a British Made anti-pick 9-pin lock from premier lock manufacturers Lowe & Fletcher
The Nemesis Ultra universal wheel lock has been tested and approved by Kiwa SCM MP03. SCM includes assessments not usually included in other procedures, such as resistance to freezing and corrosion. The accreditation ensures that the Nemesis Ultra universal wheel lock is the perfect choice for your caravan or trailer. Consider pairing with one of our Saracen hitch locks.
The Nemesis Ultra was designed in Purple Line’s UK innovation center. The product design engineers were tasked with simplifying wheel based vehicle protection, ensuring ease of use and product weight were at the forefront of their minds at all times, without compromising on security in any way.
Installation involves replacing one of your vehicle’s wheel bolts with the Nemesis Ultra’s wheel bolt receiver. The bolt acts as a permanent replacement for your existing wheel bolt. The Nemesis Ultra then locks into the wheel bolt receiver, with the toughened steel bar passing through the wheel, fouling on the vehicle’s chassis in the event of attempted wheel rotation. No need for any fiddly alignment.
Specifications
- Weight 3.25kg
- Height 150mm
- Width 270mm
- Depth 430mm
- Storage Bag Yes
- Keys Supplied 2
- Prevents Wheel Removal Yes
- Prevents Wheel Rotation Yes
- Wheel Fitment Through Wheel
- Alloy/Steel Wheels Both
- Wheel Nut Thread 12mm x 1.5mm
- Wheel Nut Cone 60 Degree Conical Seating
FNU200
