GasStop Emergency Gas Shut-Off Valve
(2 customer reviews)
£34.99 Inc VAT
Out of stock
Email Me When Back in Stock
SKU: 8719326036151 Categories: , , ,
Use gas safer with GasStop!
SAFE: 100% auto shut-off in the event of a major gas leak
SIMPLE:Easy to install and use, no professional help needed
PRACTICAL: A useful indicator shows when gas is running low
GasStop is an emergency gas shut-off device for bottled and portable gas systems used for camping, caravans, and motorhomes.
It instantly shuts off the gas flow if a leak occurs, and also includes a useful pressure gauge that lets you know when your gas is running low, letting you plan your refill ahead of time.
GasStop can also be used to test for minor leaks prior to using your gas – you should always check to make sure your gas system is leak-free!
  • Ideal for caravans, motorhomes, boats and more
  • 5 year manufacturer’s warranty
  • For propane LPG cylinders using low-pressure regulators (up to 50 mbar)
MKGS111
Weight 0.86 kg
Dimensions 43 × 32 × 4 cm
Reviews (2)
2 reviews for GasStop Emergency Gas Shut-Off Valve
  1. Suzanne Rendell (verified owner)
    Easy to fit and it’s good to be able to see the amount of gas in the bottle
  2. David Hunt (verified owner)
    Worked really well, just as described.
Add a review
£34.99 Inc VAT
