Brandrup Inside Isolite for VW ID. Buzz Cabin Windows – 5 Piece
£104.99 Inc VAT
Check out the full ID. Buzz Brandrup range HERE
This 5-piece Inside Isolite Set from Brandrup is the perfect accessory for your VW ID. Buzz, covers the entirety of the front end to give privacy and also keep the van warm.
In summer, the solar heat is reflected outwards, and the interior reflecting lamination preserves the cold air inside the vehicle longer.
In winter, the Isolite reflects the cold outwards and the warmth back into the interior: “Insulated flask effect”!
How To Use:
- Insert the Isolite into the frame of the windscreen
- Attached is a specially developed velcro to withstand different temperatures
- Attach the velcro to your van, and line up with the velcro attached to the Isolite (this is along the black stripe of your glass)
- Slot the inlays for A-pillars into place.
The Velcro’s benefit is that it allows a perfect seal on all 3 sides, which also means the enclosed air (between the window pane and Isolite) cannot escape upwards or downwards depending on the season.
What is included:
- Main Windscreen Isolite
- Isolite for Drivers Window
- Isolite for Passengers Window
- Isolit for Drivers A-Pillar
- Isolite for Passengers A-Pillar
Made in Germany
100 701 663
Frequently bought together
- Brandrup Inside Isolite for VW ID. Buzz Left Rear C-D Pillar Window (SWB)Pre-Order
- Brandrup Inside Isolite for VW ID. Buzz Left Sliding Door Window (SWB)Pre-Order
- Brandrup Inside Isolite for VW ID. Buzz Right Rear C-D Pillar Window (SWB)Pre-Order
- Brandrup Inside Isolite for VW ID. Buzz Right Sliding Door Window (SWB)Pre-Order
- Brandrup Inside Isolite for VW ID. Buzz Tailgate WindowPre-Order
- Brandrup Outside Isolite for VW ID. BuzzPre-Order
