Husky Textile Winter Ice & Snow Socks for VW T5/T6/T6.1 & VW Multivan (T7)- Pair
£44.99 Inc VAT
Please allow 1 week for delivery!
Order Now
SKU: 8424332627964 Categories: , , Tags: , ,
We have been selling these to Cali owners for the past few years and have had some great feedback about them, very handy to just have sitting in the Cali during the winter months, Please ensure your tyre size is listed below before ordering, we can also confirm these do fit the standard Cali tyre: 235/55/17 (it is not listed on the guide for some reason) it also fits the tyres used on standard 18″ alloys 255/45/R18 – For the Multivan, these fit the ‘Syrakus Allow Wheels’ 215/65/R16 tyres
The Textile Snow Sock from Husky is designed to be used on snow and ice, and is a great alternative to snow chains, Made from a synthetic waterproof fabric, the snow socks gives a consequent increase in the coefficient of friction between wheel and snow or ice surfaces. As a result the Textile socks are effective on snow & ice & gives a much more comfortable ride than traditional snow chains.
  • Lightweight and easy to fit
  • Can be used without any deterioration in the circumstances of the alternation of snow and ice, as well as alternating sections of asphalt without the need of bringing them
  • Certified and compatible with ABS
  • Does not cause any harm to the tyres
  • TUV Safety Tested and Approved
  • Proven durability according to the highest European quality standards.
  • Reusable and Washable.
  • Completely made of fabric with no metal parts, so wont damage tyres or cause vibration whilst driving
  • Snow socks work in a way that they are automatically and perfectly centered on the tyre after a very short period of use.
  • It is impossible for them to fall off while driving under normal conditions.
  • Carry bag with handle (ideal for storing snow socks when not in use)
  • Comes in attractive packaging
The special surface shape, together with the high quality textile used for the tread cover, lets you obtain:
  • The snow socks composition, high-resistance fabric, improves its durability and makes it absorb water, so as to reduce the amount of lubricant between the parts in contact, which increases the grip.
  • A significant increase in the total contact area with snow or ice, owing to both the special textile construction and the use of multi-filament thread, with a consequent increase in the coefficient of friction between the wheel and the snowy or icy surface.
  • The penetration of the relief moulding, caused by the localised fusion of the snow or ice made by the increase in pressure contact in correspondence to the textile knots, which give the textile its exclusive “grip”
  • A higher adherence between the inside surface of the textile and the tyre, so as to avoid any slippage between sheath and wheel
  • The limitation of wear on the raised part of the moulding, thus conserving the underlying thread from direct contact with the asphalt when driving on non-snowy roads
  • Maintenance of a good work ability even in cases of small flaws, thanks to the “run-proof” quality of the textile as a consequence, they are effective on snow and ice, driving and braking are precise and stable, its long life lets you drive comfortably for relatively long distances even on roads where snow and ice patches alternate with dry asphalt.
Safety Instructions:
  • Carefully assemble
  • Safely drive: do not exceed 30mph/ 50 kmh, do not make sudden accelerations or stops.
  • Quick & Easy Install Takes 2 Mins: Stretch the snow sock over the top of your tyre and pull down as far as possible.
  • Turn smoothly
  • Suitable for use in France
  • Not allowed for use in Germany and Austria
Weight 1.65 kg
Dimensions 44 × 18 × 14 cm
Be the first to review “Husky Textile Winter Ice & Snow Socks for VW T5/T6/T6.1 & VW Multivan (T7)- Pair”
£44.99 Inc VAT
