Kampa Dometic Awning & Tent Repair Tape (7.5cm wide x 50cm Length)
£4.49 Inc VAT
In stock
Kampa Repair Tape is exceptionally sticky, flexible, waterproof and airproof tape that will adhere to most surfaces for fast, extremely durable repairs to thousands of items. The tape is matte and provides an almost invisible finish meaning that there’s no need to colour match the tape. It’s also great for transparent surfaces, like tent windows and the rear window on car hoods.
The tape will stick to natural and synthetic fabrics including nylon, polyester, vinyl, rubber, plastic & canvas. Ideal for repairs to tents, awnings tent windows, inflatable products including tents, toys, airbeds, self-inflating mattresses, waterproof clothing, wellingtons, boots and shoes, car hoods, bicycle tyres, sleeping bags, horse rugs, umbrellas, sails, bags, paddling pools, water sports, fishing & hunting gear.
Great for an instant repair
Sticks to virtually anything
Long-lasting waterproof repairs
Self-adhesive
High tensile strength
Water and airproof
Flexible
High abrasion resistance
Matte, transparent finish
Ideal for: Tents and awnings, waterproof clothing, car hoods & outdoor gear
Instructions for use
The area to be repaired should be clean and dry. Cut a patch, it should overlap the tear/damage by at least 25 mm (1inch) in all directions. Round the edges of the tape for a longer-lasting repair. Trim and loose threads and then pull back the edges of the tear/damage together over a hard flat surface. Removing the backing sheet from the tape and apply to the tear damage and smooth down from the centre outwards using a smooth hard tool ensuring any air bubbles are pushed out.
The tape can be applied to the inside or outside surface or both sides, if accessible, for an even stronger repair. Can also be used in conjunction with Kampa Repair Solution for the ultimate repair. Ensure that the repair tape extends at least 6 mm beyond the repair solution.
9120000440
Weight 0.03 kg
Dimensions 14 × 23 × 3 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Kampa Dometic Awning & Tent Repair Tape (7.5cm wide x 50cm Length)”
You may also like…
  • Kampa Tent & Awning Repair Kit
£4.49 Inc VAT
