Sale!
Kampa Dometic Gale 12v High Pressure Electric Pump
(3 customer reviews)
Original price was: £57.99.Current price is: £52.99. Inc VAT
In stock
Kampa Dometic Gale 12v High-Pressure Electric Pump
A 12V electric pump designed specifically for use with Kampa and Dometic AIR awnings and tents. Simply plug into a 12V power source using the extra-long cable, set the required PSI of your awning first and switch on, and let the pump take care of the rest
This pump allows an already easy-to-erect Kampa Dometic awning to take even less time; the pump will cut out once the PSI is reached
With 6 fitting nozzles, the Kampa Dometic Gale is an ideal addition to your camping set-up as it will inflate most inflatable items
An important thing to remember for the Kampa Dometic Gale 12v High-Pressure Electric Pump: For the pump to begin working, the Gale must be informed of the intended PSI. Once the PSI is reached, the pump will stop
Designed, tested, and approved by Dometic Kampa for use on AirFrame awnings and tents.
  • Powered by a 12V car socket
  • Can inflate up to 12.5 psi (0.86 bar)
  • Digital backlit display
  • Cut’s out at pre-set pressure
  • 6 fitting nozzles
  • Suitable for inflatable awnings, tents, and other inflatables
Gale Carry bag sold separately HERE
Operating Manual
9120000437
Weight 2.2 kg
Dimensions 31 × 23 × 14 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Reviews (3)
3 reviews for Kampa Dometic Gale 12v High Pressure Electric Pump
  1. william chilvers (verified owner)
    Great product at a very good price. I have bought from CVB before and always good. I did send an email on ordering but did not get a reply which was unusual.
  2. Clifford Callow (verified owner)
    Had to buy this to replace a failed ‘Kampa Breeze’ pump, as Kampa no longer provide any parts or service options? – That was disappointing, but having said that the new ‘Gale’ model does the job in half the time. – 5 Mins to inflate a 400 Pro-Air awning. – Another annoyance is that the new pump doesn’t fit the original carry bag, so it seems Kampa / Dometic have all the cards stacked in their favour? – Happy with the product for now.
  3. mickmartin23 (verified owner)
    Exercise bit of kit
Add a review
You may also like…
  • Kampa Diddy ceramic fan heater
  • Kampa Dometic Gale Pump Carry/Storage Bag
  • Kampa Cuboid PTC Compact Fan Electric Heater (750/1500w)
    Original price was: £29.99.Current price is: £22.95. Inc VAT
