Kampa Limpet Suction Drive Away Awning Kit
The Kampa limpet suction drive-away awning kit is the perfect solution when you do not have an awning rail on your van
- 6mm to Limpet™ Fix System
- Simply attach the Limpets through the pre-cut holes in the driveaway kit and fasten to a smooth surface
- Supplied with 6 Limpets
- 3 metre length
9120000419
| Weight | 1.03 kg |
| Dimensions | 97 × 8 × 8 cm |
![s-l1600[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2015/07/s-l16001.jpg)
