Kampa Pro Windbreak – 5 Section
The Kampa Pro Windbreak 5 gives you vital protection from the wind. Made in the same material as our Pro awnings, it is quick to set-up and is supported with adjustable support bars. The windbreak provides a level of privacy and Crystal Clear transparent panels mean that you’re not completely cut-off from your surroundings.
Improved for 2019, the Pro Windbreak now features an aluminium frame; this massively reduces the weight of the windbreak and helps prevent corrosion. Additionally, Pro Windbreaks can now be connected using figure-of-8 strips (AC0325) which is sold separate, to create a larger protected area. If you wish to create an enclosed area, a zip-up door panel is also available to allow access (WB0003) which is sold separate.
- ‘Feel the Difference double coated Weathershield Pro polyester
- Adjustable Alloy support poles, no need for guy lines
- Comes with strong carry bag and pegs
- Crystal Clear horizontal panel
- NEW – Pro Windbreak Door ready
- Also available three panel versions
Specifics
- 16.3kg
- W1cm x D765cm x H140cm
- Pack away 100 x 19 cm
9120000357
