Kampa SabreLINK 150 LED Lighting System – Add-on   Awning and Tent light
Kampa SabreLink 150 Add-on can be used along side the SabreLINK 150 starter kit to add more lighting to your awning from 1 starter kit you can add 2 add-ons.
An exciting new accessory for your awning, the SabreLink™ lighting system ensures you’re never in the dark. The system allows you to link up to three lights together – that’s 450 LED’s. Each of our AirFrame awnings is SabreLink™ ready and can accept lights on the front AirPoles and also the centre poles. An Ace AIR Pro 400, for example, could have three lights along the front and another three in the centre.
Each system is controlled using a remote control that allows you to switch the lights on and off and also dim and brighten them. In our poled awnings the lights can be hung from the horizontal poles using the ‘S’ hooks provided.
  • Avaliable as starter and add-on kits
  • Up to three lights can link together
  • Operated using a remote control
  • Brightness can be adjusted
  • Velcro tabs on all Kampa AIR awnings from 2016 for easy fitting (caravan and static motorhome awnings)
  • 150 super bright LED bulbs – never need replacing
  • 5 metre cable (starter kit)
  • Complete with mains adaptor in starter kit (UK and EURO plug versions available)
  • S-hooks included for other awnings and tents
  • Optional 12V adaptor available
9120000339
Weight 2 kg
Dimensions 20 × 20 × 132 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Be the first to review “Kampa SabreLINK 150 LED Lighting System – Add-on”
£27.99 Inc VAT
