Kampa Dometic Tailgater Drive Away Poled Awning
(1 customer review)
£329.00 Inc VAT
Delivery 5-7 Days
Pre-Order
A universal fit awning for vehicles with a rear tailgate such as SUV’s, MPV’s, crossovers, large estate cars, campervan and pick-up trucks fitted with a hardtop with a height of no more than 225cm
Simple to attach and to disconnect, The Tailgater can be closed up while you go out and explore.
  • Fibreglass poles
  • Freestanding Drive-Away awning
  • Weathershield™ material
  • A massive 6000mm hydrostatic head
  • Seams hot air taped – for maximum weatherproofing
  • Large end ‘D’ door with mesh screen
  • Very large side door with mesh screen
  • Adjustable sleeve to fit a wide range of vehicles
  • Full clip-in groundsheet
  • Window blind
Specs
  • Maximum height: 225 cm
  • Packed Size: 74 x 25 x 25
  • Weight: 9 kg
9120001231Kampa Dometic Tailgater Drive Away Poled Awning
Weight 12 kg
Dimensions 70 × 28 × 25 cm
Kampa Dometic
Dometic make the world more mobile. Their motivation is to create products with outstanding design for use in recreational vehicles.
Reviews (1)
1 review for Kampa Dometic Tailgater Drive Away Poled Awning
  1. Michael (verified owner)
    Nicely packaged and looks great quality. Instructions are clear and backed up by photos, which I followed to the letter when setting it up in the garden. Not put a tent up for years so I struggled a bit specially with the central pole but it is brand new so a little tight engaging into pocket.
    Pole sleeves are not plastic but fabric ‘netting’ so be careful sliding them through but I think it’s a great idea as when windy they won’t act like sails pushing the tent about so much!
    The main poles are tricky when attaching the pins into the end pole as the fabric catches on the central pole making it a little difficult to slide along, I’m gonna slide the poles through then pin into one end pole first then feed fabric as I bend and slide through to other end!
    It’s easier than my explanation I assure you and once up you just square it off & peg it down with guy ropes. It’s quite large so plenty of room, not tried ground sheet or car attachment but very pleased with it overall, definitely recommend & it’s smart in the grey colour scheme. Pegs are steel but be careful hammering into the ground they can bend easily but I’ve not had too much issue with them previously on early tents.
    Got it all back in the bag ok, it has quick release straps that cinch it tight. Looking forward to using this with the grandchildren.
Add a review
You may also like…
  • Kampa Travel Pod Tailgater Footprint
    Original price was: £22.99.Current price is: £9.99. Inc VAT
  • Kampa Twin Drive Away Awning Kit 6mm/4mm to 6mm – 4 Metre
£329.00 Inc VAT
