Sale!
The Vango Galli Low poled drive away awning is ideal for anyone who wants a large and versatile space on their outdoor holiday.
With enough space for two double bedroom inners, or to just enjoy family meals together, the Galli is the perfect awning for family breaks. The attached canopy also makes for a great space to relax outside no matter what the weather. Created using Vango Sentinel Active fabric in a stylish new colourway, it is extremely lightweight, ideal for when space-saving is important. Featuring PowerFlex® Fibreglass Poles for a strong and reliable structure and Vango’s patented Tension Band System for extra stability in windy conditions. Multiple vehicle attachment options make set up easy whilst the roll away tunnel allows you to drive away, leaving the Galli free-standing when you go exploring for the day.
- Optional Carpet Available – Give your awning all the comforts of home without compromising your outdoor experience
- Optional Groundsheet Protector Available – Protects built in groundsheet from rough ground. Prevents awning base getting wet and dirty, allowing easier pitching, packing and storage
- This awning has multiple additions available for enhanced functionality – Please check our additions table for more details
- Tunnel Adjustment Strap – Helps collect any excess material and creates a neater looking tunnel and a tighter fit to the vehicle
- AirZone Ventilation – High and low level ventilation panels combine to create a comfortable flow of air throughout the awning, which is essential for reducing condensation
- Covered Entry – Gives a sheltered entrance into your awning, which prevents rain from dripping into the living area
- Diamond Clear Windows – Maximise light and visibility to provide a bright and airy environment
- Drive Away – Using the addition of a Drive Away Kit, detach the tunnel area of your awning from your vehicle and roll it away leaving your awning free standing as you explore for the day. Keep a note of your parking position for when you return and re-attch the awning to your vehicle
- Easy Access Doors – A flat entry access door creates easy access for wheelchairs, prams and people with reduced mobility
- Easy pack Carry Bag – Oversized carry bag to make it easier to pack the awning away
- Experience Poled Awnings included with – Pre-attached 6mm kador strip, over vehicle webbing straps, roof bar attachment tabs, sleeve for pole & clamp, steel pegs with carry bag and carry bag with compression straps
- Vango PowerFlex® Fibreglass Poles – Creates a strong, yet light and reliable structure
- High Visibility Guylines – High visibility lower half to prevent tripping hazards and ensure stability in high winds
- Lantern Hanging Points – Conveniently positioned to attach your light(s) with ease
- Mesh Front Door – Fitted with internal mesh fly screen for bug-free ventilation
- Multiple Vehicle Attachment Methods – All our awnings come with pre-attached 6mm kador, 8M over vehicle straps, roof bar attachment tabs and sleeve for pole & clamp kit system. This ensures our awnings are compatible with any vehicle
- Roll Away Connecting Tunnel – Detach your awning when you drive away for the day, simply roll back the tunnel and toggle it to secure
- Sentinel Active Fabric – When pack size and weight are the key influencers in choosing your awning, our specifically designed Sentinel Active fabric will surpass your needs. Sentinel Active is strong, whilst being fully waterproof, ensuring great quality and performance coupled with compact pack sizes
Fully Sewn-in Groundsheet – Groundsheet is attached to the flysheet with an external storm skirt to provide a bug and draught free environment - Side Attachment – Awning attaches to your van with a side attachment to ensure you are always facing the view wherever you go
- Supplied with Steel Pegs – Strong and durable pegs ideal for grass pitches. Supplied with a handy carry bag
- TBS®II Tension Band System – Ensures awning performs in adverse conditions, especially in strong, changeable winds. When tensioned, the bands brace the beam or pole at 3 points and prevent sideways movement. Adjust TBS®II to remove slack. Do not over tension, as this may deform the poles. Can be stowed away in calm weather
- Toggled Privacy Curtains – Easy to use privacy curtains that can be simply rolled away when not in use
- Two Doors in Tunnel Attachment to Vehicle – For convenient access to the front or back of your vehicle
- Touring Awning – This awning is designed for touring use; it is not designed for static or long-term seasonal pitching as extensive exposure to UV light will cause accelerated fabric degradation. UV degradation is not covered under the warranty. However, under normal holiday use your awning will give long service
Data
- Weight 16.8kg
- Packsize: L75.0 x H31.0 x W31.0cm
- Awning Size: Low
- Pitching Time: 12 mins
- Kador Adjustable Height: 180-210cm
- Weight without Accessories: 9.2kg
- Height:210.0cm
- Length: 465.0cm
- Width: 320.0cm
- Kador Length: 240
AWTGALLPO000001
Please Allow 3/5 Days Delivery on this item.
| Weight | 10 kg |
Reviews (1)
1 review for Vango Galli Low Poled Drive Away Awning
You may also like…
Vango Drive Away Awning Kit 6mm to 6mm (3m Length)
Original price was: £21.99.£18.99Current price is: £18.99. Inc VAT -
Vango Drive Away Awning Kit – 6mm to 4mm (3 Metre)
Original price was: £18.99.£14.99Current price is: £14.99. Inc VAT
Original price was: £499.99.£399.99Current price is: £399.99. Inc VAT
![s-l1600[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2015/07/s-l16001.jpg)
![4593_source_1731582914[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2024/10/4593_source_17315829141.jpg)
Philip Bates (verified owner) –
Great awning and good price. Also super fast delivery. But:
Three guy ropes were half missing. Not a problem as we have spares.
12 minutes to erect – who are they trying to kid. 30 minutes for experienced campers. Watch the u tube video first to save your marriage.
