Kontrol Mini Moisture Trap - Lavender Scent
Kontrol Mini Moisture Trap – Lavender Scent
£2.49 Inc VAT
In stock
SKU: 5017996501058 Category:
Small & compact, yet highly efficient; the Kontrol Mini Moisture Trap is ideal for keeping control over moisture during colder months whilst fitting into small spaces and not looking unsightly.
With a Lavender scent, the moisture traps also act as a freshener in your van/caravan/car/motorhome
This holds the class-leading Kontrol Krystals in a stylish and compact container. The container has been designed to easily fit on shelves and window ledges making it easy to place exactly where you need to.
Simply remove the foil on top, and the trap starts working. Simple to use and with a spill proof design. Ideal for those smaller areas where the standard traps do not fit.
They even fit on our Large Kitchen Shelves for the California!
How they work:
Kontrol Crystals Anhydrous flakes of calcium chloride (CaCI), have a high affinity to water and readily attract excess humidity from the air by a simple chemical process.
When used in a moisture trap the krystals begin to coagulate (sometimes developing a discoloured crust) and eventually, after a few weeks and depending on levels of humidity/dampness, liquid will begin to collect in the base of the moisture trap.
Kontrol crystals will continue to function effectively for up to 2-3 months after exposure to the surrounding air. For optimum results place the moisture trap into areas where there is a damp or moisture problem, replacing the krystals when the process is complete.
  • Combats Damp
  • Helps Stop Condensation, Mildew and Musty Odours.
  • Removes Moisture.
  • Ergonomic Design.
  • Fits almost Anywhere.
  • Battery Free.
  • Works Day and Night
  • Lasts Approx 6-8 Weeks
Specifications
  • Capacity: 100ml
  • Material: Anhydrous flakes of calcium chloride.
  • Size: 10 x 7.5 x 5cm.
Be the first to review “Kontrol Mini Moisture Trap – Lavender Scent”
£2.49 Inc VAT
