Maypole 6mm to 4mm/6mm Dual Beading Drive-Away Awning connection Fixing Kit - 3m
Maypole 6mm to 4mm / 6mm Beading Drive-Away Awning connection Kit – 3m
(1 customer review)
£18.99 Inc VAT
AC0313
Only 2 left in stock
Maypole 6mm to 4mm/6mm Dual Beading Drive-Away Awning connection Kit – 3m
Wanting to be able to drive away from your awning?
Maypoles 6mm-6mm/4mm drive away awning fixing kit is suitable for vans, caravans, camper vans and motor homes (as long as the rail fitted to the van is 6mm or 4mm ).
This drive away kit is quick and easy to use, allowing you to attach and detach your awning within minutes. Simply thread the kader strip into the rail on your van, then slide the figure of 8 onto this. Your awning then slides into the remaining side of the figure of 8 and you’re good to go!
  • Water resistant to 1000mm
  • Kader strip is 150D Oxford fabric with PVC coating
  • Figure of 8 attachment pcs are PVC
  • UV stable
  • Kit includes: 3m 4/6mm Kader strip, 3 x 1m figure of 8 extrusions
  • A handy storage bag
  • MP9567
Weight 1.03 kg
Dimensions 97 × 8 × 8 cm
Maypole
Maypole are the UK & Ireland's leading towing and touring company. Buy trailers and trailer accessories, trailer lighting, caravan, and car accessories.
Reviews (1)
1 review for Maypole 6mm to 4mm / 6mm Beading Drive-Away Awning connection Kit – 3m
  1. Ian (verified owner)
    What’s not to like? Does the job, good quality, reasonably priced, and as usual quick delivery.
Add a review
£18.99 Inc VAT
Subtotal: £2,075.91
View basketCheckout
