Mercedes Vito V-Class Fiamma 2.7m 270 Roll Out Awning and Fitting Kit (2014 Onward). No drilling is required with this Fiamma F40s 2.7m and fitting kit
It comes with the brackets to fit the awning to the long-wheelbase Mercedes Vito and V-class vans. Please be aware this kit will not fit if you have a pop top roof or awning rails fitted to your van.
No drilling of the bodywork is required in order to fit this kit as it uses the mountings that the roof rails use.
Available in Black, Titanium Silver or Polar White.
Providing a generous 5.8 m? of shade surface, the awning features a smart aluminium case in deep black with a waterproof, washable and UV resistant canopy in a cool Royal Grey vinyl material, coloured both sides.
It’s sturdy, easily safely operated and is silent when opening and closing and when packed up and on the road.
The F40s can be easily operated by a single person and the winding mechanism is incredibly smooth and easy to use. The further benefit of the F40s is that the canopy is under a constant tension thanks to the reinforced arms – enabling you to set to a desired extension.
The Fiamma brand is synomous with quality and their wind out awnings are the respected, go-to, choice for both owners and converters alike.
Specifications:
- Awning length A: 270 cm
- Canopy length B: 257 cm
- Extension C: 225 cm
- Shade Surface: 5.8 m?
- Weight: 19 kg
These are delivered directly from the supplier, someone needs to be home to be able to sign for the delivery. Any damage, please report this to the driver and sign as damaged.
Detailed fitting instructions can be seen? -> here <-
| Weight | 7.5 kg |
| Dimensions | 60 × 40 × 20 cm |
| Colour | Black, Polar White, Titanium Silver |
Mercedes Vito V-Class LWB Fiamma F40s 2.7m 270 Roll Out Awning and Fitting Kit.
£924.99 Inc VAT
