Mestic Foldable, Compact 100w Solar Panel MSFO-100
£134.99 Inc VAT
Only 2 left in stock
SKU: 8712757483556 Categories: , ,
Mestic’s compact folding solar panel, weighing 3.8 kg, unfolds and can be placed wherever you want/need.
When folded, the panel measures just 47 x 43.5 x 4.5 cm, making it easy to store in the motorhome, caravan, or tent.
The Mestic Solar panel Foldable MSFO-100 has an output of 100 W.
The panel comes with a stand that allows you to easily position it at this angle and features monocrystalline PERC solar cells which produce more energy than standard solar cells. This technology improves the reflection of sunlight meaning more sunlight is converted into energy.
The solar panel features 108 solar cells and has a high efficiency. The durable construction allows the solar panel to perform well even in harsh conditions, making it perfect for an off-grid camping holiday.
There is a hidden USB-A & USB-C Port to allow you to charge devices directly from the solar panel.
Combined with a power station (not included), you can use the generated energy directly for your electrical appliances.
Kit Contains: XT60 extension cable – MC4 connector
Top Tip For maximum sun coverage, position the folding panel at a 35° angle.
Specifications
  • Made of high-quality PERC solar cells
  • Foldable and compact
  • Power: 100 W
  • Solar cells: 108
  • Dimensions unfolded: 149 x 47 x 2.5 cm
  • Dimensions folded: 47 x 43.5 x 4.5 cm
  • Weight: 3.8 kg
  • Maximum voltage: 19.5 V
  • Maximum current: 5.13 A
You can find the manual ->HERE<-
A0020216
Mestic
Be the first to review “Mestic Foldable, Compact 100w Solar Panel MSFO-100”
£134.99 Inc VAT
