Sale!
Mestic MGC-200 Double Gas Cooker with Electric Ignition – FULL BUNDLE DEAL
BUNDLE DEAL – Double Gas Cooker, Reversible Plate, Windshields & Storage Bag!
The Mestic MGC-200 30 mbar cooker is equipped with two powerful 2.2 kW burners and an electric ignition for an optimal cooking experience.
Thanks to the non-slip feet on the bottom, the stove stays firmly in place.
The camping cooker is equipped with a lid, so the flame does not blow out easily.
Where you’d normally have to buy the accessories separately, we’ve saved you the hassle and bundled them together for an unmissable deal
What is included?
- 1 x MGC-200 Double Gas Cooker
- 1 x Reversible Plate (Grill & Bake)
- 2 x Windshields
- 1 x Storage bag with carry handle
Main benefits
- Two 2.2 kW burners (that can be used independently)
- Non-slip feet
- Gas consumption of 320 g/h at 4.4 kW
- Electric ignition (battery supplied)
- Adjustable Thermostat
- Heat-resistant Housing
- Indicator Light
- Easy to assemble, wipe clean, and store
- Full bundle, simply pack up and go
How do I use the cooker?
When you want to cook, open the lid and simply connect the stove to a propane or butane gas cylinder using the screw or hose connection. Only use the appliance in well-ventilated areas.
Once connected to the gas supply, you can get started right away and prepare the most delicious meals.
Finished cooking? Then you can easily clean the appliance thanks to the removable pan support. Cover the appliance with the lid and place it in the storage bag.
Mestic cookers are perfect for outdoor use. This two-burner cooker offers space for several pans at the same time, or a combination of a pan/kettle and your frying pan!
Find the Manual HERE
Original price was: £94.99.£79.99Current price is: £79.99. Inc VAT
![pre-order-cubo-breeze-v2-campervan-awning-olpro__34240.1721396565[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2024/10/pre-order-cubo-breeze-v2-campervan-awning-olpro__34240.17213965651.png)
