Sale!
OLPRO Hive Poled Campervan Drive Away Awning with Sleeping Pod
Price range: £465.00 through £562.20 Inc VAT
OLPRO Hive Poled Campervan Drive Away Awning with Sleeping Pod is a six sided drive away awning with a connection height of 190cm – 250cm and plenty of living space. It has a sleeping Pod attached to the side so it does not use up your valuable living space or if you remove the internal bedroom this increases your living space even further! The Hive has an impressive five windows that give you a three hundred and sixty view and the skylights in the roof fill the Hive’s living area with light.
The tunnel has two access doors so no need to walk through the awning to get to the van and the sleeping pod has an extra large inner tent that will fit a double air bed or can be removed to enlarge your living space. The awning is made from an above-standard 190T Rip-stop, fully waterproof material, with a rating of 5000 Hydrostatic Head and it also has fully taped seams. The poles are a mix of steel and fibreglass, providing extra stability. The front door has the benefit of a fly mesh screen for added privacy and to protect you from those pesky bugs.
Specifications
Will Fit: All vehicles between a height of 190cm and 250cm
Colours Available: Blue, Grey and Lime
Height (cm): 240cm (94.48″)
Length (cm): 330cm (129.92″)
Width (cm): 330cm (129.92″)
Packed Dimensions (cm): 60cm x 40cm x 40cm (23.62″ x 15.74″ x 15.74″)
Weight (kg): 18kg
Hydrostatic Head: 5,000mm H/H
Material: 190T OLTech
Poles: Fibreglass Roof poles & Steel Leg Poles
Awning Beading: 6mm
Sewn-in Groundsheet: Yes
Pitching Time: 25 Minutes
Number of Doors: 2
Number of Windows: 4 & 6 Roof Skylights
Bedroom Inner: Yes – 2 – Berth Darkened
Standing Room: Yes
What’s Included? Pegs, Guy Ropes, Storm Straps, Tunnel Throw Over Straps, Carry Bag, Repair Kit, Poles
Weight 18 kg
Dimensions 60 × 40 × 40 cm
Add Ons
No Add Ons, Carpet and Footprint
OLPRO
Here is our range of OLPRO products
Be the first to review “OLPRO Hive Poled Campervan Drive Away Awning with Sleeping Pod”
You may also like…
  • OLPRO Hive / Hive Breeze - Carpet
  • OLPRO Hive / Hive Breeze - Footprint Groundsheet (with pegs)
