Outdoor Revolution 5 in 1 Lumi Fan USB Lantern/Fan/Spotlight
£18.99 Inc VAT
In stock
Found this item cheaper?A clever 5 in 1 USB charging lantern, fan and spot light that can be used either on a flat surface or can be hung from a lantern hanging point in your tent or awning, with its fold out hanging hook. The lightweight, compact size and multi-functional capabilities of our portable ‘Lumi-Fan Lite’ makes the intelligent USB rechargeable 5 in 1 LED lite, fan and spotlight a modern day camping essential! This fantastic accessory can be suspended from any of the designated hanging points in your tent or awning using an integral hanging hook, but is also perfect for handheld use, or use on a flat surface. Both the lantern light and spot light incorporate three brightness settings, ranging from a faint night light to a brilliant ceiling light. The fan is directional and can be positioned in almost any way, to suit the user’s personal preference, making it ideal for cooling down after a tough day of exploring, this features three speed options. A Powerbank charging port has also been integrated onto this model, allowing you to conveniently charge up any alternative electrical devices.
- LED lantern light with 3 brightness settings
- Pivoting LED spot light with 3 brightness settings
- Pivoting air circulating fan with 3speed settings
- USB Charging – Compatible with the USB 12v Charging hub. Complete with charging cable
- Fold out hanging hook
- Charging Time: 9 hours
- Spot Light Working Time: Full :7hrs
- Fan Working Time: Full: 4hrs
ORBK0014
Weight | 1 kg |
Dimensions | 21 × 21 × 21 cm |
