Sale!
Outdoor Revolution Portable Compact Solar Lantern Square USB
Original price was: £9.99.£6.99Current price is: £6.99. Inc VAT
Out of stock
Email Me When Back in Stock
Outdoor Revolution Portable Compact Solar Lantern Square USB. Ideal for a campervan or tent, this light is lightweight small and compact, making it a great choice for spacesaving.
This Portable Solar Lantern from Outdoor Revolution is also perfect for wild camping and festivals as it can be used when there is no power supply to hand.
Ideal for hanging in the living area of a tent or awning by using the metal pivoting arm you can change the direction of light to where it needs to be, you can also use this metal arm as a stand or a hook
Dual charging is available on the back of the light with a USB port – USB charging lead is included
Multi-level output so you can change the ambiance within your living area with a brightness up to 100 lumens
- 3.7V, 1000mAh Li Battery
- LED 0.06W LED x 25 pcs
- Rainproof to IPX4
- Charging Time by USB: 2 hours
- Lighting Working Time: 6 Hours high mode / 50 Hours low
Specifications
Size 8.6cm x 8cm x 3.2cm
Total Weight 0.08kg
ORBK0019
| Weight | 1 kg |
| Dimensions | 21 × 21 × 21 cm |
You may also like…
