Outdoor Revolution Camp Star Rock N Roll King 100mm Self-Inflating Mattress
Introducing the new colourway for 2024: Monument and Dark Slate.
Here we have the Campstar Rock and Roll King 100mm Self-Inflating Mattress by Outdoor Revolution. A Fully reversible self-inflating mattress that can be used with both European factory-built campers and UK van conversions – Ideal for the VW California and RIB 112cm beds and similar sized beds (please check before ordering)
The official sizes of this King 100 mattress bed are 180cm x 112cm x 10cm but after inflating one it is ever so slightly bigger at approx 183cm x 115cm – as the sides are rounded.
Constructed from a robust Peach polyester on both the fabric top and base, this mattress is reversible and constructed from a 12cm deep flat foam with horizontal drill holes making it lighter and more compressible in use.
The mat is inflated through 2 patented one-way Cyclone Valves located at the bottom of the mat to effortlessly inflate and deflate the mat quickly and efficiently.
  • The top and fabric is made from 75D*150D Peach Polyester with an embossed PVC coating
  • The base and fabric is made from 75D*150D Peach Polyester with a plain PVC coating
  • Flat horizontal drilled foam insulation at 10cm depth for a 4 Star Comfort Rating
  • COLOURS: Top Adriatic Blue
    Bottom Monument
    Side Dark Slate
  • Supplied with a compression stuff sack with draw cord closure
  • Supplied with 2 compression bands to help pack it away neatly
  • Care instructions are provided
Specification
  • Weight 5.8kg
  • Size 180 x 112 x 10cm
  • Pack Size 60 x 28 x 28cm (albeit not square)
  • Top Fabric: 75D*150D Peach Fabric, embossed with PVC coating (Grey in colour)
  • Bottom Fabric: 75D*150D Peach Fabric with PVC coating (Grey in colour)
  • Side Wall Fabric: 75D*150D Peach Fabric with PVC coating
  • Foam: Flat with horizontal drill holes
  • Carry Bag: 75D 150D Peach Fabric, with PA coating (Grey in colour)
  • Valve: 2pc Cyclone one way Valve (patented)
The video below showcases the Outdoor Revolution King 120 which is last year’s model but has the same mechanism to the New King 100.
ORSM1120
Weight 3.4 kg
Dimensions 66 × 30 × 22 cm
Outdoor Revolution
''Designed in the UK, enjoyed globally. Innovative Awnings, Tents and Outdoor products for over 20 years.''
Reviews (5)
5 reviews for Outdoor Revolution Camp Star Rock N Roll King 100mm Self-Inflating Mattress
  1. Mike Hopkins (verified owner)
    Just used our new mattress for the first time. Once I’d worked out the values rotate it inflated quickly.
    Made the California standard bed so much more comfy.
    Packed down easily this morning and popped back in its back. Perfect!
  2. Andrew Ingram (verified owner)
    Used for first time for wales trip. Made the RIB bed extra comfy! Just rotated the vales to squeeze out the air and rolled up with the quilt and put in the “ boot space “ behind the seat when put back into position. When needed, bed down and rolled into position ready made and rotated valves to inflate. Excellent!!
  3. benschofield0 (verified owner)
    Excellent mattress.
    Comfy and is worth it for the extra width.
    Fits our titan bed perfectly.
  4. David Llewhellin (verified owner)
    It was a long time on back order but worth the wait. Fits our rock and roll bed perfectly, inflates in minutes and easy to adjust the comfort level with the rotating valves. It is a bit of a struggle to fully deflate and roll up in the confined space in the van, however a outdoor revolution mini max air pump in deflation mode helps to get the last of the air out. We have only used on one camping trip so far but is a lot more comfortable than our previous thinner self inflating mattress and we particularly like the fact that once deflated it doesn’t try to re-inflate before you shut the valves off.
  5. pshawkes (verified owner)
    Great product, makes the bed comfortable. You have to be careful not to over inflate it with the Iutdoor Revolution Mini pump I purchased at the same time. I ended up putting a bit of pressure into the bed and letting all of it out by opening the valve but putting no pressure on the bed. This let’s the mattress give a bit. I used it with a memory foam topper. Packing away is intersting, the mini pump does not have the correct adaptor to suck efficiently, if you are buying one get the adaptor. I ended up using my Dyson V6, deflates it in seconds and actually did back in the bag. Haven’t dared putting it upstairs with the memory foam mattress, seem too many bent roofs on the internet. Recommended.
Add a review
You may also like…
  • Outdoor Revolution 12V USB Charging & Power Hub
    Original price was: £19.99.Current price is: £17.99. Inc VAT
  • Vango California POP 5cm Double Sleeping Mat – Shadow Grey/Red
  • Outdoor Revolution Top of The Pops Self Inflating Pop Top Roof Mattress 5cm
£119.99 Inc VAT
