VW California
Caravan
Drive-Away Awnings
Tents
Outdoor Revolution Cayman Annexe
£179.00 Inc VAT
Out of stock
Email Me When Back in Stock
The Cayman Annex is a must-have for owners of the 2021 Cayman Air & Cayman F/G. It zips simply onto the rear of both models providing a tall sleeping extension complete with a darkened ‘Twilight’ micro-polyester two-berth sleeping pod. Pitched simply using one robust yet lightweight fibreglass pole, this annex is designed to sleep up to two adults, a double air bed, or three children. There is an internal sewn-in groundsheet which means the inner tent can be removed to allow the annex to be used as additional storage or living space should you wish.
The Cayman range is produced from a premium ultra-lightweight 120HDE fabric weave, which has been specifically engineered to deliver lightweight, compact and visually contemporary products that pack away neatly into the inclusive carry bag, making it perfect where weight or space limitations are of key consideration. This material incorporates a 3,000mm Hydrostatic Head and employs fully taped seams throughout, meaning it is exceptionally waterproof and rain will simply bead onto the surface, before rolling off.
The Cayman Annex is securely fitted to the awning using a zip with a weatherproof cover, simply zip off the rear panel on the Cayman F/G or Cayman Air (2021 onwards) and zip the annex on. Thread the fibreglass pole through the fabric and fix it in place using the pre-attached pins, finish by pegging all pegging-points and guyropes ensuring all edges are tight and straight.
  • 120HDE high density all-weather lightweight fabric
  • Hydrostatic head 3,000mm
  • Lightweight yet robust fibreglass poled frame
  • Rear Phoenix mesh ventilation panel
  • Includes 2 berth sleeping inner tent
  • Hi-vis guylines with quick adjusters
  • Fits 2021 models and later
Specifications
  • Total Weight 4.8kg
  • Pack Size 74x25x38cm
  • Footprint 200 x 200cm
ORDA1009
Outdoor Revolution
Manufacturer of premium caravan awnings, drive away awnings, family tents, canopy extensions, gazebo shelters and camping accessories.
Be the first to review “Outdoor Revolution Cayman Annexe”
£179.00 Inc VAT
