Outdoor Revolution Movelite T4E PC Annexe
£244.99 Inc VAT
Only 2 left in stock
Found this item cheaper?Outdoor Revolution Movelite T4E PC Annexe
The Movelite PC Annex is a must-have for owners of a Movelite T4E PC awning, simply zip out the rear panel on your awning and zip this in. Made from the same exquisite breathable polycotton fabric as your awning, it provides a tall sleeping extension complete with a darkened ‘Twilight’ micro-polyester two berth sleeping pod. Pitched simply using a single air tube, this annex is designed to sleep up to two adults, a double air bed, or three children. There is an internal sewn-in groundsheet which means the inner tent can be removed to allow the annex to be used as additional storage or living space should you wish.
- Breathable premium weather-proof Polycotton fabric
- Oxygen Air Frame with DSV & IF valve system
- Zip-on weather proof attachment system
- Includes 2 berth inner tent
- Designed to fit the 2021 Movelite T4E PC
- Includes peg set and carry bag
Specifications
- Total Weight 7.7kg
- Pack Size 76x31x26cm
- Footprint 200 x 220cm
Product Code: ORDA2048
