Outdoor Revolution Cayman Curl Air Drive Away Awning (180 – 210cm) Low
Original price was: £499.00.£299.00Current price is: £299.00. Inc VAT
Out of stock
Email Me When Back in StockOutdoor Revolution Cayman Curl Air Drive Away Awning (180 – 210cm) Low
The Cayman Curl Air is a lightweight Inflatable Drive-Away awning designed in the popular side-by-side style, meaning the front of the awning faces the same direction as the front of your vehicle. It’s small pack-size and simplicity to pitch using two air-tubes and a single fibreglass pole makes it a fantastic choice for touring vehicles. The Cayman Curl 2022 model has the option to attach a Zip-On Porch Door which will fully enclose the front porch. This porch door creates a huge amount of additional living space, and also allows for the addition of a ‘Cabin Inner’ bedroom which when used alongside our standard 2 berth inner means there is ample sleeping capacity for up to 4 people.
The large open canopy is perfect for sunshade, to use as a cooking area, or for weather protection while the main front door is open. There is also a large door in the rear of the cowl to allow access to the vehicle without the need to come through the awning itself. A rear ventilation panel coupled with under-window vents and mesh in the cowl door help to maintain airflow inside the awning while minimising condensation, and of course, there are Velcro points to hand our Lumi-Link and Lumi Lighting range.
Specifics
- 120HDE Hex high density all-weather lightweight fabric
- Hydrostatic head 3000mm
- Oxygen Air Frame system with 2 tubes
- Extended for 2022 – Integral front canopy with fibreglass poles
- Facility to take an optional accessory cabin sleeping inner tent when used in conjunction with the optional Porch Door accessory (2022 model)
- Zip back 2/3rds front door with side window
- Integral, full canopy with fibreglass pole
- Inner cowl tension straps and cowl bungee for an adjustable vehicle fit
- 4mm & 6mm twin cowl connection rail piping
- Rear-facing zip back cowl access door
- Crystal clear PVC windows with toggle in privacy blinds
- Fully sewn-in PE groundsheet
- Hanging points for optional 2 berth sleeping inner tent in living area
- Colour-coded guylines with quick adjusters
- Adjustable webbing pegging system
- Includes manual air pump, peg set and carry bag
- Low Connection height 180cm – 210cm
- Cowl Depth 120cm
- Total Weight 15kg
- Pack Size 78x43x33cm
- Footprint 300 x 360cm (+120cm cowl depth)
- Rail Connection Width 260cm
ORDA1072
Frequently bought together
You may also like…
Outdoor Revolution Inflatable Campervan Draught Excluder (SWB Version)
Original price was: £84.49.£74.99Current price is: £74.99. Inc VAT -
Outdoor Revolution Cayman Porch Extension Cabin Inner Tent
Original price was: £98.50.£69.99Current price is: £69.99. Inc VAT
