Outdoor Revolution Eclipse Pro 330 Air Awning 2022 Model
£899.00 Inc VAT
Out of stock
Email Me When Back in StockOutdoor Revolution Eclipse Pro 330 Air Awning 2022 Model
The all new Eclipse Pro 330 is set to become a firm favourite amongst tourers this season. Based on the popular width of 3.3m the Eclipse Pro 330 boasts a myriad of features including our famed Dura-Tech fully welded airframe with single point inflation for super-fast pitching. As with all our premium awnings, the frame is protected by our Intelligent Frame system (IF) which regulates the air pressure and protects from over-inflation, this is backed up by our lifetime air tube guarantee. The Eclipse Pro 330 has plenty of ventilation, with toughened zip back breathable mesh panels built into both side doors, letting in plenty of air whilst keeping out flying bugs. A full zip in mesh accessory door is also available for both side doors, perfect for warm climates, another great addition for the Eclipse pro 330 is the optional Conservatory Annex which can be zipped to either end of the awning creating a large sleeping area, or a windowed conservatory/storage space.
The Eclipse collection is produced from a technical high performance 600HD high density oxford weave, which provides the aesthetics, tactility and resilience of a traditional awning, whilst retaining extraordinarily lightweight properties, balancing the usability of man-made fibres and tactility of natural fabrics; this not only creates a refined sense of luxury, but provides vital weight and space saving benefits. The material is exceptionally water resistant, featuring a hydrostatic head of 6,000mm, therefore water will simply bead onto the surface, before rolling off. A lighter coloured roof material reflects heat to help maintain a pleasant internal temperature.
The Oxygen Air Frame is the quickest, simplest and most reliable inflation system on the market, with no adjoining pipes/taps spoiling the immaculate lines of our stunning designs. The Oxygen Air Frame comprises our welded single point inflation Oxygen Air Frame technology, which utilizes a series of interconnected high-pressure tubes, the famed Dynamic Speed Valve and our patented Intelligent Frame Relief Valve. Inflation is swift using the Dual Action Hand Pump provided, whist deflation is just the push of a button. The exclusive pressure relief valve prevents damage to the tube through expelling any excess air, which is usually caused by overinflation, or fluctuations in the ambient temperature; each valve is discretely concealed by a Velcro cover. This Dura-Tech Welded Oxygen Air Frame has been quality controlled to ensure optimal performance and carries our exclusive Lifetime Guarantee* for peace of mind in years to come.
Expansive tinted anti-glare windows and roof skylight panels permit an excellent vista of the surrounding outside world, whilst protecting against any harmful UV rays, increasing privacy and maintaining an airy internal atmosphere; these are accompanied by zip-in curtains, which can be zipped completely back to illuminate your caravan awning, or fully in for total privacy on an evening. We have added Twin Piping (6mm x 4mm) to this model, permitting compatibility with caravans and motorhomes, within the corresponding height range. Ventilation is paramount our designs, which is why the each of the side doors are accompanied by a Phoenix Mesh ventilation fly screen panel to optimize air circulation and keep insects at bay; an assisted healing ‘smart’ material, with the structurally incorporated ability to repair ‘snag’ damage, typically caused by consistent usage over time. Simply manipulated, the mesh will then return to its original form.
The Eclipse Pro 330 is supplied complete with a draft skirt and mud wall to trap heat within the caravan awning, which helps to maintain a more comfortable internal temperature. We have included a dual action hand pump, repair kit, adjustable tensioning storm straps, reflective guylines, steel ground pegs, underwing ventilation points and attachment points for our Lumi-Link Tube Light Kit & Up/Downlighter LED lighting systems. An array of complementary optional extras are also available to purchase, including a conservatory annexe extension, coordinating windbreak, breathable carpet, mesh door panels, a waterproof roof liner and rear pad poles.
FEATURES
- Pro 600HD high density all-weather premium fabric
- Hydrostatic head 6,000mm
- Inflatable Dura-tech fully welded tube Oxygen Air Frame system
- LIFETIME GUARANTEE on the Air Frame System (T’s & C’s apply)
- Dynamic Speed Valve & Intelligent Frame relief valve system
- Front left and right zip-back doors with left hand mesh panel
- Full walk in (195cm) height side door entrances
- Zip-out left and right side doors with zip back Phoenix mesh panels
- Zip-on side annexe option (fits left or right side)
- Tinted anti-glare PVC windows with leaf design zip up curtain blinds
- Tinted anti-glare PVC roof windows
- Ground Anchor Webbing secure guying system
- Adjustable webbing pegging system
- Includes pump, draft skirt, peg set, storm straps and carry bag
SPECIFICATIONS
- Total Weight 24.87kg
- Pack Size 81x51x43cm
- Footprint 250 x 330cm
- Awning Piping Length 420cm
- Height Range 235cm – 250cm
OPTIONAL ADDITIONS
- Eclipse Pro 330 Treadlite – (325×240) TRE330
- Eclipse Pro 330 lounge liner – ORCA2006
- Eclipse Pro zip in side full mesh door (left & right compatible) – ORBK3488
- Eclipse Pro annexe – ORBK3496
- Roof tension kit – ORBK1080
- Rear pad poles – POL220
- 2 berth clip in inner tent – ORBK5600
- Awning Storage Hanger – ORBK3580
ORCA2000
Sizes | 260, 325, 390 |
