Outdoor Revolution Oxygen AIR Windbreak
Outdoor Revolution Oxygen AIR Windbreak (130 x 470)
£199.00 Inc VAT
The Oxygen Pro Windbreak is the most practical, flexible, and innovative windbreak on the market. Joining Outdoor Revolution’s growing collection of exclusive registered designs; this high quality, three-panelled inflatable windbreak has been designed to effectively deflect wind for up to 4.9 metres around your touring arrangement, whilst featuring a coordinated design to complement the contemporary aesthetic of our latest Airedale & Movelite collections. The modular design means that this windbreak can be infinitely extended, as much as you desire, using our single panel accessory extensions which simply connects using a plastic figure of 8 section. Each section is flexibly hinged, enabling you to adjust the configuration of the windbreak to suit your personal preference. An upper window panel has been positioned on each section, allowing you to retain an excellent outlook of any surroundings, whilst relaxing behind the windbreak.
  • 240HDE high density all weather lightweight fabric
  • Inflatable oxygen air frame with boston style valves
  • PVC crystal clear window on centre panel
  • Flexible hinged system with Kador & figure ‘8’ connection enables panels to be removed or extra panels to be joined together to create a longer windbreak
  • Elastic bungee peg down points
  • Colour coded guylines
  • Complete with air pump, pegs & carry bag
Total Weight 6.9kg
Pack Size 59 x 22 x 24cm
Pitching Time 15 mins
ORWB4000
Blue Diamond
Blue Diamond Products Ltd are UK manufacturers and suppliers of quality caravanning, camping and general outdoor equipment. We offer original, practical and durable products to the market, either manufactured here in the United Kingdom or sourced from across the globe.
Be the first to review “Outdoor Revolution Oxygen AIR Windbreak (130 x 470)”
You may also like…
  • Outdoor Revolution Oxygen Pro 3 Single Panel Extension
  • Outdoor Revolution Oxygen Pro AIR 3 Panel Windbreak
  • Outdoor Revolution Oxygen 3 Single Panel Accessory Extension
£199.00 Inc VAT
