Outdoor Revolution Portable 1200w Gas Cartridge Heater
£49.99 Inc VAT
Out of stock
Email Me When Back in Stock
Outdoor Revolution’s new Portable Gas Heater is very compact, and easy to use. This heater has an impressive 1200W power output and is compatible with our own Iso Butane 220g Gas Cartridges. Employing some clever safety features makes this gas heater the safest on the market, incorporating a tilt switch that will automatically shut off the gas flow if the unit is accidentally knocked over, and an ODS valve that cleverly shuts down the heater if the oxygen level gets too low (Oxygen Depletion Sensor). Ideal for camping and fishing trips in the colder months, or as an extra heater in any outdoor space or in any emergency.
The Portable Gas Heater is very easy to use and is ignited with a built in Piezo Ignition switch. The heat output can easily be controlled by the twist and turn knob on the side. It is robust and made from enamelled steel body with a chrome plated wire fire guard covering the ceramic burner plate. The heater comes with easy to follow step by step guides to get the best performance and highlights how to stay safe when using the appliance.
Features/Specs
  • Construction: Enamelled steel
  • Safety: ODS & Tilt Switch
  • ODS – Oxygen Depletion Sensor.
  • Tilt Switch – Gas cut off when tilted or knocked over
  • Fuel: 220g butane / propane gas cartridge
  • Burner Type: Ceramic plate
  • Ignition: Piezo ignition
  • Power Output: 1200 Watts
  • Fuel Consumption: 90g/h
HEAT2100A
Weight 2.1 kg
Dimensions 28 × 32 × 15 cm
Outdoor Revolution
''Designed in the UK, enjoyed globally. Innovative Awnings, Tents and Outdoor products for over 20 years.''
Be the first to review “Outdoor Revolution Portable 1200w Gas Cartridge Heater”
£49.99 Inc VAT
