Sale!
Outwell California Highway Drive-Away Air Awning (175-200cm)
Original price was: £699.95.Current price is: £519.99. Inc VAT
Check out our bundle deal for this awning –
1 left in stock >> here <<
Out of stock
Email Me When Back in Stock
New for 2025, the Outwell California Highway Driveaway Air Awning is specifically designed to fit the VW California, alongside other vans of a similar build and height!
Made using a rigid air system, the inflatable tubes efficiently ensure fast and simple inflation, meaning you can set up your extra living area within minutes.
With the main opening being parallel to your van, the California Highway allows for a large open plan space with easy access to your vehicle, in Summer months you can open the front of the awning and allow for great airflow to your van, avoid those pesky insects by zipping the flynet to. An additional side door allows for extra options, allowing you to position your furniture inside the awning in whichever formation you like, as you can still access the awning from other points.
At the heart of the California Highway is the innovative Outwell Nightlight System, offering ambient lighting for easy orientation and improving the awning’s spacious feeling. Already having great standing headroom, the NightLight System adds to the great sense of being outdoors.
Large openings, both at the front of the awning and the side, can be unzipped and rolled back to add even more space and ventilation, with flynets on both to keep those unwanted mosquitoes and flies out.
Its robust structure includes Duratec fibre-glass poles and a double-coated waterproof polyethylene groundsheet, ensuring it stands firm against the elements.
The composition of this awning is completed by Outtex® 4000 Select polyester, a material known for its excellent performance and durability.
Practical down to its very pack size of 75 x 35 x 35 cm, effortless transport and storage are a great feature of the Outwell California Highway Air Driveaway Awning.
  • Compact inflatable awning
  • Vertical front wall with canopy
  • PVC free DuraAir tubes
  • Prepared for unique integral Outwell Nightlight System (patented) that offers ambient light for easy access and orientation
  • Pre-shaped air tubes provide great headroom and interior space
  • Double zips allow full front opening, backed by full mesh panel for insect-free ventilation options
  • Spacious living area with large tinted windows for a light-filled interior with curtains for privacy
  • HookTrack System for versatile positioning of lights and items up to 1.5kg
  • Heavy-duty Outwell zips are easy to use, running securely and freely
  • Groundsheet for Link Access Zone with built-in draught excluder skirt
  • Full open rear for easy access to the vehicle
  • Additional side door with mesh panel behind for good ventilation and flexible access
Specifications
  • Roof connection length: 250 cm
  • Attachment height: 175 – 200 cm
  • Bead thickness: 7 mm / 5 mm
  • Flysheet: Outtex® 4000 Select polyester
  • UV protection: UPF 30+
  • Sewn-in groundsheet
  • Hydrostatic Head: 4000 mm
  • Textile fiber composition: Fly: 100% Polyester Mesh: 100% Polyester
  • Tubes: Rigid Air System for fast and simple inflation
  • Groundsheet: Double-coated waterproof polyethylene
  • Poles: Duratec fibreglass 9.5 mm
  • Pack size: 75 x 35 x 35 cm
  • Weight: 15.4 kg
111500
Why not check out our full range of driveaway awnings designed for campervans HERE
Below you can find the User Manual
File:PDF file icon.svg - Wikipedia
Outwell
Outwell the INNOVATIVE FAMILY CAMPING. Tents, vehicle awnings, camping furniture, and accessories.
Be the first to review “Outwell California Highway Drive-Away Air Awning (175-200cm)”
