Powerpart C-Line Twin USB Socket – 5 Volt 1 Amp & 2.1 Amp – Dark Grey
£9.99 Inc VAT
Only 1 left in stock
Found this item cheaper?Powerpart C-Line Twin USB Socket – 5 Volt 1 Amp & 2.1 Amp – Dark Grey
Part of the Powerpart electrical range – C-Line is a modular range of wide range of electrical Components & Facias that mix and match to suit whatever your requirement you have.
They are interchangeable with CBE Style Facias etc and are fitted in a wide range of Caravans & Motorhomes including but not limited to: Bailey, Elddis, Adria & Coachman.
This is the perfect solution for the addition of a twin USB socket at 5 Volt (1 amp and 2.1 amp) if you’re converting a van or need a replacement for your caravan or motorhome.
In dark grey, this will fit in with any interior design.
