750mm propane pigtail gas hose with M20 fitting to attach to a standard propane bottle and at the other end a M20 nut fitting – fixes directly onto the caravan or motorhome via fixed bulkhead regulator that will be fitted to all caravans and motorhomes from 2004 onwards
Caravan Connection: M20 / W20
High pressure LPG hose
R7HPRO
| Weight | 0.86 kg |
| Dimensions | 43 × 32 × 4 cm |
![s-l1600[1]](https://vwcaliforniaclub.com/shop/wp-content/uploads/2025/11/s-l16001-7.jpg)
